cam help
Old Feb 16, 2008 | 04:00 PM
blown 04's Avatar
Default cam help
Ok guys please help me out here, im in the middle of my cam install and just
got done changing out the ls6 springs with 918. Now im ready to pull the cam from the block, I got to 5/16 dows from lowes shoved them in but i can still push the lifter back down on the cam. Doesnt seem like they do nothing. I dont have pen magnets should I get them or just spin it a yank it out and quickly install the new one?
Old Feb 16, 2008 | 05:09 PM
sbw9056's Avatar
I used dowels when I did my cam. I had a lifter slip past a dowel and partially block the cam bore. Fortunately, I was able to take a metal rod with a short 90 degree bend in it and tap the lifter back up into the bore. Obviously, I am not a fan of the dowel rod method. Next time I will be using pen magnets.
Old Feb 16, 2008 | 07:04 PM
jakebdb56's Avatar
A good easy way to find out if the lifters will stay up is put pushrods in, but no rockers. Rotate the cam a few revolutions and you'll see all of the pushrods go up. If you can let them sit there and not move at all over several minutes you're good to go. The stock lifters in my truck stayed in the trays very well, most likely because I only had 34k miles on the truck.
Old Feb 16, 2008 | 07:24 PM
ap2002's Avatar
same way a member from here and I did the cam on my brothers truck 2 weeks ago, but the only difference was that my bro. truck had 100kmiles!! I was sweating it!!
Old Feb 16, 2008 | 07:32 PM
agreif's Avatar
I thought someone showed a picture of how the dowels didn't really retain the lifters, just a note those lifters trays were designed to keep the lifters up (even though some don't when they wear).
Old Feb 17, 2008 | 03:01 PM
blown 04's Avatar
Cam is in, seems to be ok. I used the 5/16 rods but i can tell you the lifters can still fall
down. seems to pull pretty hard in the mid to upper range, waiting on tune from Allen for the cam change, hope runs even better after that.
Old Feb 17, 2008 | 04:12 PM
jakebdb56's Avatar
It should run a LOT better with the tune, what kind of boost are you running at WOT?
Old Feb 17, 2008 | 05:05 PM
blown 04's Avatar
Im running 8lb at wot, I hope it was worth the time! Thanks for everyones help!!
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
