Cam guys
Old Feb 2, 2012 | 05:33 PM
  #31
Beatdown Z's Avatar
Laid Back
Great converter choice.
Make sure you get the oil pump centered on the crankshaft before you torque it down.
Old Feb 2, 2012 | 06:44 PM
  #32
Team Paulie's Avatar
Registered User
I got the LS-1 how to bible glued to my windshield so I'm going step by step.
Should I do the ARP Heads studs,ARP Head bolts or GM bolts?
I got GM bolts but if I can get something better and not have to re buy bolts or swap out if I go turbo....
Old Feb 2, 2012 | 07:16 PM
  #33
neilownz's Avatar
Arp are reusable.
Old Feb 4, 2012 | 11:58 AM
  #34
Registered User
Anybody got any tips or tricks as far as the timing and what not?
Just have the timing cover to pull and is there any thing else I gotta know or watch out for?
Old Feb 4, 2012 | 01:32 PM
  #35
JFOLM's Avatar
The ls1howto write up pretty much covers it.
Old Feb 6, 2012 | 10:35 AM
  #36
Registered User
Should be pretty easy, I got the heads off already.
Old Feb 16, 2012 | 03:00 PM
  #37
Registered User
Can you install head studs with the engine still in the truck?
Old Feb 16, 2012 | 03:02 PM
  #38
Ferocity02's Avatar
I believe so. You might want shorter rods with the LS7 lifters, they are 0.05" taller than stock. Lots of people are running 7.4" rods though, you will just have more preload than normal. If you mill the heads or run a thinner gasket then you definitely want shorter rods. A pushrod length checker is the only for sure way to know though.
Old Feb 16, 2012 | 08:36 PM
  #39
gasmachine85's Avatar
LS1Howto.com is pretty legit... used it alot on my first ls powered machine and it helped a ton. If your an ls newb, tons to learn from that site...
Old Feb 17, 2012 | 03:48 PM
  #40
Registered User
Cam set up is gonna go into a 2006 LQ4 now,not gonna mill the heads and gonna use a stock GM gasket kit. might send the 7.4's back and get one step shorter.
