cam and convertor combo
Old Mar 24, 2014 | 10:08 AM
  #81
bizle's Avatar
Yea we will be street tuning on our way to the dyno and finishing everything up on the rollers
Old Mar 24, 2014 | 11:10 AM
  #82
maroon88iroc's Avatar
I think I am going to pickup a Pro King "GM55" Converter for my 04 GMC SLT 1500. The converter is a I6 trailblazer converter.
Old Mar 25, 2014 | 07:13 PM
  #83
bizle's Avatar
Spent the day installing my cam kit
Im going to try like hell to get on the dyno by this weekend
Old Mar 25, 2014 | 08:15 PM
  #84
GREENSIERRA's Avatar
Originally Posted by bizle
You mind sharing the specs on your cam?
223 226, 610 605 110+4
I actually have to much low end with this setup and have traction issues.
in my 6L I am building the cam specs are 230 238 604 604 113 to help with traction for street shenanigans
Old Mar 25, 2014 | 09:15 PM
  #85
1ownerCHEVY's Avatar
How did your install go? Thats my next mod but still very undecided on what grind to go with. Trying to get as much knowledge on the install though for when I do decide what to get.
Old Mar 26, 2014 | 08:47 AM
  #86
bizle's Avatar
It wasnt to bad. I bought the crane valve spring tool so i could do two springs at once. It still took awhile to do the springs
Also i bought the tool to install my crank pully and two 5/16 oak rods to hold up the lifters just to be safe.
it took me about 9 hours to do everything by myself.
I installed the electric fans and nelson harness at the same time.
I ran into two issues. I got in a hurry and forgot to connect my air line to pressurize the cylinder And by by valve. Luckly i was able to spin the motor by hand and woohoo talk about luck lol
And at the very end not thinking i decided to fire it up just to make sure everything was ok. It started right up and sounded great but next time i will put the radiator in first Lol forgot about the trans cooler lines and made a mess of my garage floor lol.
Old Mar 26, 2014 | 08:53 AM
  #87
bizle's Avatar
Anybody know where i should set my shift points with this cam?
Also where do you guys set your lock up for your convertors? Mine seems to lock around 45mph and i hate it.
Old Mar 26, 2014 | 02:06 PM
  #88
gamble686's Avatar
Preference will decide the shift point. 6200 is really common.
Old Mar 26, 2014 | 04:21 PM
  #89
69Camaro427's Avatar
Mine used to lock up at 45 and it was a bogger, I now have it set to 55 which is perfect for me since the rpms are around 1400 in lock up and not bogging.
Old Mar 26, 2014 | 08:43 PM
  #90
bizle's Avatar
What size gear you running?
