cam choice for 03 tahoe
Old Jul 10, 2005 | 12:44 AM
91_bowtie's Avatar
Default cam choice for 03 tahoe
I've been looking at cams for my 03 tahoe for a while now, and I think I've narrowed it down to the TR224 & XR275HR. Performance wise, all that I have is a K&N FIPK, TransGo hd2, and Nelson 93 hot tune. I'll be looking for a yank tt3000 soon, but I doubt I'll be able to do it when I cam it. Am I headed in the right direction? I don't want to go too big, but I do want to see a noticeable increase in torque. Is there another cam that you guys would recommend instead, and why?
Old Jul 10, 2005 | 12:49 AM
FILE's Avatar
How concerned are you about driveability?
Old Jul 10, 2005 | 01:22 AM
99Silver6.0's Avatar
That should do you good. You will need that stall in there!! If you dont go for a Nelson tune, since I see you are in KC, you could always hit up MC Racing or Supertune for a dyno tune. That cam might be much for what you want honestly. That thing will rip up dam high in the RPM's. Might want to stick to a bit lower duration cam if this is a daily driven truck. Comps 212/218 is availible in 2 lift versions. Either of those might be better suited to your truck. Or you could step it down from a TR224 to a TR220.
Old Jul 10, 2005 | 01:59 AM
91_bowtie's Avatar
Driveability is a big concern.
I already have the Nelson tune, but I don't want to leave anything on the table. I'll have to talk to allen about my options.
So you guys think the 220 would be better?
Old Jul 10, 2005 | 02:12 AM
I just put the TR224/112 in my 5.3. It is by no means a mild cam, but drivability should be good after I get it re-tuned on tuesday. Right now I'm shifting at 6000 and it wants to pull alot longer than that. It's lope sounds mean...that is if I can get it to idle right now it will idle in park if I'm lucky but otherwise I'm twofooting it around town. I'll report back to you after I get it tuned. Oh, and a stall is a must have for this cam.
Old Jul 10, 2005 | 10:56 AM
go with something a bit milder, like 99silver5.3 said. For a tahoe, and a daily driver, the 212/218 low lift should give you hella low end, and you could probably do w/o the stall too.
Old Jul 10, 2005 | 11:44 AM
bluecajun5.3's Avatar
11 Second Truck Club
the 224 and 220 are too big. i would go with the comp 212/218 like 99silver with a 2500 stall the most
Old Jul 10, 2005 | 01:48 PM
litreddevil's Avatar
Banned
You Can Go With The 216/220 525/532 114 * You Still Need A Converter For Best Results. That Is The Cam I Have,the Only Other Cam I Would Go With
Would Be The 212/218 But The Higher Lift.
Old Jul 10, 2005 | 01:52 PM
Just dont over-cam it. You put a huge cam in a little motor its gonna pull to the moon. You dont want a 5.3 shifting at 7000 if you drive it daily. Dont buy a cam for the lope, you will regret it.
A tune on the dyno or out on the street is the way to get your tune spot on. You wont leave anything on the table.
Old Jul 10, 2005 | 11:10 PM
91_bowtie's Avatar
Lope is the last thing I'm looking for from this swap. I thought the tghter LSA would keep the torque lower in the powerband, but I don't want alot of wasted topend that I will rarely take advantage of.
So, of the two Comp 212/218's, what are the advantages of the lower lift & 114 LSA vs the high lift & 115 LSA? I'm guessing the stock pushrods willl be fine with this combo? I do plan on using the 918 springs.
I think I just wasted $490 by having nelson tune it, instead of someone local.
