Cam Bearings too narrow
The bearings look like theyre wrong, stock bearings should be .765 i believe and there is another bearing ive seen listed that are something like .62x, dont know difference but i would think overtime the narrower bearing would cause issues....
You need the .765 bearings... Enginetech pn is cc433w only because i have a set sitting here.... If you want gm part numbers for updated coated bearings, i can get those here in a few.... There was a bulletin on the cam bearings
There are three different size bearings 2.345 1/5, 2.325 2/4, and 2.306 3 journals in the block cam journals are all the same ....the bulletin is about the updated coated cam bearings.... Get numbers here in a few minutes
