Cam Bearings too narrow
Old Feb 12, 2016 | 12:09 PM
Wolftrk99's Avatar
This is from enginetechs catalog part lookup on their website
Old Feb 12, 2016 | 12:12 PM
CF7GO's Avatar
Called the machine shop....after dealing with the ***** on the phone he finally went and got the build sheet. They are the Durabonds CH-23. Horrible customer service. Never using them again.....
Old Feb 12, 2016 | 12:13 PM
Wolftrk99's Avatar
The 23s should be for gen 3 blocks... The 25s are for the gen 4
Old Feb 12, 2016 | 12:17 PM
CF7GO's Avatar
So they do need to be changed? He claimed the thickness wont matter.
Old Feb 12, 2016 | 03:06 PM
Wolftrk99's Avatar
As many issues as the gen iv engines have with cam bearings i want the proper bearing in there
Old Feb 12, 2016 | 09:55 PM
Beatdown Z's Avatar
Laid Back
Gen3 cam bearings are way smaller than Gen4's. Impossible to install them in the wrong block. I installed the narrow Durabonds in my LS2 a couple thousand miles ago and it's doing fine.
If it will make you sleep better at night, throw some wider bearings in there. The machine shop did nothing wrong, imo.
Old Feb 12, 2016 | 10:13 PM
Wolftrk99's Avatar
Not saying the bearings are wrong and wont work, or anybody did anything wrong... i personally would just prefer the wider bearings the gen iv blocks call for with all the issues they have with cam bearingsto begin with!!
Old Feb 12, 2016 | 10:15 PM
Beatdown Z's Avatar
Laid Back
After thinking about it, I think the only reason wider cam bearings were used was because of the big *** groove cut in VVT camshafts.
Old Feb 12, 2016 | 10:22 PM
Wolftrk99's Avatar
Oh you mean the oil robbing groove that all the vvt and afm cams have, could very well be the reason they went to the wider bearings but iirc the cam journajs in the gen iii blocks are narrower too, could be wrong been a while since i pulled a gen 3 down at this point and when i built my 6.0 in the 99 i wasnt into taking pics of everythingthe way i am now....
fishboy
Feb 15, 2016 11:30 AM
ShtBox93
Feb 11, 2016 09:34 PM
iDEALS1
Feb 9, 2016 10:39 PM
Merctech2
Jan 22, 2016 06:33 PM
Dbar72
Jan 15, 2016 07:19 PM
