cam advice
Old May 23, 2004 | 02:46 AM
SuthernFlames316's Avatar
Default cam advice
i have a 99 5.3...i plan on bolting some stage 2 patriot heads on. What would be an good cam to accomodate them. I have a 9 inch lift kit and i have 38 inch tires. they are pretty heavy. i changed the gears to accomodate the tires. i just need advice for an excellent cam that will provide me with alot of power for those tires.
Old May 23, 2004 | 03:30 AM
Hit Man X's Avatar
I'll try to answer some of your q's from other threads here also...
Instead of getting big buck heads I'd get a pull out 6.0 and get a cam in there. The 6.0 has a MUCH larger bore which is going to give you more power all over. The 6.0 heads are just large chamber Z06 heads also. I'd treat them to a mild polishing of the runners then stick them back on. Perhaps mill them a bit for more compression.
I think single pattern cams yield more torque than dual patterns. A good cam most like here is the 212/218 ~.520/.530 114LSA more power from idle to 6000+rpm.
A blower is a good way to add a lot of power quick but you're gonna drop an easy $5K for that Radix then another ~$2K for a tranny rebuild. N/A power tends to be more plesant to the driveline.
A 6.0 w/ warmed up heads, nice cam, and full exhaust would really shine. 325-375rwhp should be attainable. I'd consider a mild stall converter also. 2400-2600rpm is nice and will allow ya to tow...if you don't tow I'd get more stall...like I plan to.
Old May 23, 2004 | 01:38 PM
creederado's Avatar
I agree,
I just did a cam,springs,rods gasket kit,pulley bolt, etc..
good increase but for alittle more I'm finding 6.0l complete pull outs poping up close and closer to my area. anywere from $1000 to $2500.
I was thinking heads to go with my 212/218 high lift cam/stall/4.10/5.3 reg cab but after seeing the price and the fact I have the Ti rets and springs already I'm staying away from them.
I would do the 6.0l if I were to do it over again.
Even with my all bolt on cam 5.3 I don't think I'm close to the 6.0l.
Old May 23, 2004 | 04:27 PM
greentahoe's Avatar
Originally Posted by creederado
I agree,
You just completely answered the questions Ive been wrestling with for the last several days.
Old May 23, 2004 | 07:40 PM
treyZ28's Avatar
you probobly want low end, not top end I'm assuming. In this case Id honestly go with a 6.0, cleaned up heads and a cam for that but if you are not looking to spend that much money, heads/cam will work. Id talk to www.cmotorsports.com for heads. Heads are hand ported (at least my LT1 ones were) to meet whatever your goals are, not a one size fits all kind of deal. If you are looking for low end power, dont look at flow numbers. you should concern yourself with a head that will provide a high velocity.
Old May 23, 2004 | 11:43 PM
so you are saying i should buy a whole 6.0 engine, or just put on 6.0 heads??? how much would that cost. would i have to tune the computer when i put new heads on?
ARC
57
Feb 21, 2022 10:54 AM
Castro45
24
Jul 31, 2015 07:13 PM
sauldgold
Jul 23, 2015 02:15 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
