This Cam in a 5.3L?
Old Jan 30, 2006 | 09:13 PM
v8
17,16,15,14,13,12,11 Drvr
with that cam he will have to get the patriot gold dual springs, hardend push rods 7.425 long, tunening and a 3500 stall converter, heavy trucks don't like the large duration of cams, if he can find a 212 218 high lift cam on a 114 then he would be better off, unless he likes large stalls lol, that cam in a 5.3 would pull to 7300 easy I bet.
Old Jan 30, 2006 | 10:59 PM
02sierraz71_5.3's Avatar
Originally Posted by Formulated
A friend wants to know if this cam is ok in a stock 5.3L headed 2001 ext. cab truck?
590 /590 231/231 on112
We will have to change the springs, pushrods, and a stall converter right? With a tune of course. What else would have to be changed? Will the stock pistons have to be fly-cut?
Basically he wants to just make it a cam only 5.3L
Im assuming thats at .050
truck engines dont respond to large cams like the fbods. I wouldnt go with a cam that big unless youve got the heads and intake to support it, its like trying to breath through a straw doesnt make sense.
The stock pistons should be fine with that lift but with the added duration I would still check clearances.
FYI I milled .050 and my cam has .566 lift but only 222 duration.
Old Jan 31, 2006 | 01:19 AM
That cam will suck ***** below 3000 rpm.....which is the range you do all your driving in.
Old Jan 31, 2006 | 08:40 AM
98TAauto's Avatar
thats a big cam for a fbody even lol
thats a huge cam for a truck lol.. i'd pass and just find something in the 210-220 range on 114lsa if you could. Even with me 210/218 i lost some low end. With a 231 i'd need a semi behind me to help me make it up the road below 3k lol
lawhitediamante
Aug 12, 2015 12:14 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
lxcoupe
Jul 27, 2015 08:19 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
