Cam for a 5.3
Old Oct 2, 2008 | 02:59 PM
gtosilverado's Avatar
Originally Posted by whitegmc2003
gott some more questions... for the lsx is that order specific for the cam or is it made for the cam... would 112 or 115 work better... also what stall around 3000?
i dont understand ur first question about the lsx.... 112 would be better and a 3000 to 3600 works
Old Oct 2, 2008 | 03:00 PM
Originally Posted by low5.3silverado
Will the tr220 pass smog in CA?
not sure, but im know there are ways to get around it
Old Oct 2, 2008 | 04:43 PM
whitegmc2003's Avatar
i think i said it wrong.. for the 112 does that come specific for the tr220 cam or do i have to specify that i would want a 112 when i order the cam
Old Oct 2, 2008 | 05:09 PM
nemmarick's Avatar
im pretty sure the 220/220 comes standard w/ 112LSA
Old Oct 2, 2008 | 05:11 PM
nemmarick's Avatar
i just oredered the TR 214/230 .601/.579 117 LSA
Old Oct 2, 2008 | 05:24 PM
GMCtrk's Avatar
is that the old man cam?
Old Oct 2, 2008 | 05:26 PM
circusboy's Avatar
You have to specify the LSA as 112. I had a 220/220 on a 114 LSA before I went to the cam I had now. It made great power. I had a Yank TT3000 and it was great. If your wanting to keep it mild get that one. I have a Yank SS3600 now and it's a totally different animal. You can still tow, easily, with a TT3000. IIRC people are passing CA emissions with 224's. What ever you decide, You need to plan your setup before you purchase all the parts. It will save you time and money in the long run. Some LT headers would help too
Old Oct 2, 2008 | 05:45 PM
low5.3silverado's Avatar
How?
Old Oct 2, 2008 | 05:54 PM
TouchOfEvil04's Avatar
5.3l i would stick with the 220/220 on a 114 or 112 lsa.
If you plan to rev over 6300rpms upgrade your rodend bolts to arp's so you can rev it safely. FWIW i wouldn't rev under 6500 on a 220 cam in a 5.3l.
Don't run anything smaller than a 3k stall a 3200 would be alot nicer and a 3600 would be ideal.
Longtubes will go a long way as well once you cam. Also e-fans knock a couple tenths off as well.
Don't forget gears and locker in the rear....price starts to add up fast once you consider the entire build.
Old Oct 2, 2008 | 08:55 PM
yes i understand price goes up exponentially for that next horse but i wanna keep thing slight right now nothing major... if i put in a cam and rods and springs and timing chain thing will run correctly and add more power..correct me if im wrong the other stuff like helping out the tranny, rear end and efans are not going to be EXTREMLY needed for these initial upgrades they are just the next step after
