Cam?
Old Sep 7, 2008 | 07:21 PM
D_Yurik's Avatar
Default Cam?
how practical is it for me to put a cam in my 6.0L? i tow a boat just about every weekend in the summer. If i do put a cam in, what else do i need to do, i cant just put a cam in right. I know that the truck will have to be tuned once the cam is in but will a cam alone be ok?
Old Sep 7, 2008 | 07:24 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
you could put a small cam in there without having a need for other parts (tune excepted). Most will do springs and pushrods too.
Old Sep 7, 2008 | 07:50 PM
InchUp's Avatar
Most camshafts will max out the stock springs, so those are a must-have but no worries. If you pick out a towing cam, chances are it wont max out stock LS6 springs which are only $53 bucks for the entire set of 16. A nice upgrade with very strong torque, improved mid and extended redline would be something like a 212 or 218 duration camshaft. Either one of those with low lift and a 112-114 lobe separation angle will actually get better gas mileage than your current setup, provided the tune is done after the swap. If you're trying to stay low buck, perhaps the 2001 LS6 camshaft?
Old Sep 7, 2008 | 10:18 PM
budhayes3's Avatar
PT's Slowest Truck
+1 The popular Comp 212/218, tuned accordingly, will net some nice gains and probably increase fuel economy also. Get some hardened pushrods and LS6 springs and you're good to go
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
