CAI Fitment Problem
Old May 29, 2013 | 08:12 PM
GM SpeedFreak's Avatar
Default CAI Fitment Problem
Well I finally decided to order a CAI for the 5.3. I bought the AFE magnum force stage 2. I have a problem though... I have the huge mechanical fan and the new intake tube sticks just a little too far off the throttle body and the fan is gonna clip it. Has anyone else had this problem and if so what did you do to fix it? Been kinda wanting to switch to LS1 fans so I guess this is a sign it needs to be done. Thanks for any help.
Old May 29, 2013 | 08:15 PM
ak2007r6's Avatar
Take a pic of the problem?
Old May 29, 2013 | 08:20 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Do you have a throttle body spacer? If so, remove it.
Old May 29, 2013 | 08:27 PM
Chevy_King1500's Avatar
yup will not fit will the spacer... the tube probably has a groove molded into the intake tube for it to clear the fan shroud, its fairly tight in there and is not designed to work with the spacer.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
