A/C CLUCHTH WIRE
Old Jun 9, 2003 | 03:23 PM
Default A/C CLUCHTH WIRE
does anyone know if the a/c clutch wire is in the fuse box panel on the hood??
and if so which one is it??
Old Jun 9, 2003 | 05:14 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: A/C CLUCHTH WIRE
It is in the fuse box under the hood. I have a pic that JSmith sent me. I'll send it to you.
If this is for electric fans let me just say that I don't think you really even need to hook up the A/C relay. I've been running my Flexalite 282's without the A/C relay hooked up and the fans take care of things fine when the A/C is on. I've also read that the fans come on and off alot with the relay hooked up because of how the clutch engages/disengages.
I'll send that pic to your email in a little bit.
John
Old Jun 9, 2003 | 06:19 PM
L82gofast's Avatar
John is right. I disconnected my AC wire since it cycled on and off so much. Just dial the temp down a bit and they will take care of the AC no problem.
Mike
Old Jun 9, 2003 | 06:29 PM
Hit Man X's Avatar
No crap, you don't need the fans on with the A/C?
Old Jun 9, 2003 | 06:44 PM
XLR8NSS's Avatar
Adkoonerstrator
No that's not what I meant.
The fans will still come on when the temperature rises to whatever the thermostatic relay is set to. The A/C relay is to keep a vehicle from overheating when the A/C comes on, with the 282's that not a problem. They work just like normal with or without the A/C on. It just doesn't phase them.
On my old 350 S-10 I HAD to keep the electric fans on when the A/C was on becuase it was almost too much for the cooling system and if they weren't the truck would overheat.
Maybe that explains it better.
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
