buying pacesetter headers
Old Sep 22, 2007 | 09:40 AM
kw05silverado's Avatar
Default buying pacesetter headers
anything i should know before i buy these LTs non ceramic coated. they are 1 3/4 mild steel for $264.00. I wanna make sure they will fit the stock y pipe and if i need to put sleeves on the spark plug wires. Also they have 3 inch collectors and i want to do 2.5" true duals. will it be alright or is there a better way?
Old Sep 22, 2007 | 09:51 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I'd look at getting them coated, maybe there is a shop local to you that can do it? You do live in one of the saltiest parts of the world.
Old Sep 22, 2007 | 09:59 AM
Yogi Bear's Avatar
LTs will not fit the stock Y pipe.
TooTall used the pacesetters and he didn't need any sleeves for the stock wires.
Old Sep 22, 2007 | 10:03 AM
So basically i would need an ory in order for it to fit?
And no place down here does ceramic coating. i would have to take them up to the main land.
Old Sep 22, 2007 | 10:05 AM
912jonathon's Avatar
an ory or you could have the exhaust shop connect the headers to your pipe
Old Sep 22, 2007 | 10:32 AM
is it difficult for them to modify the stock y pipe to fit the pacesetters? I dont want to buy the ory bc im gonna do the true duals. ive been searching and reading and it seems like its a hassle, with the tranny lines,and the tick noise, i guess i can deal with that, i just hope an exhaust shop can modify the stock piping to fit the headers.
Old Sep 22, 2007 | 10:35 AM
bluecajun5.3's Avatar
11 Second Truck Club
just buy the coated pacesetters, bring it to an exaust shop to run you true duals from the header back, and be done with it. end of story
Old Sep 22, 2007 | 10:38 AM
what he said^^^^
Old Sep 22, 2007 | 11:05 AM
sounds good. i hope the coating will be alright.
Old Sep 22, 2007 | 12:22 PM
adam1803's Avatar
i have uncoated pacesetters and the only thing i notice from them is radiant heat in the floor boards. And why even worry about the y-pipe if your doing true duals?
