bunghole problem on headers !!
Old Mar 31, 2013 | 10:21 AM
D.J Vasquez's Avatar
Default bunghole problem on headers !!
the threads on my 02 sensor bung on the header are strip! any solution on how i can fix it .i've tried jb weld and it onley works for a couple days !if i dont get into it hard !!today i've bought some thread locker and the liquid jb weld and im not going to drive it until tomorrow !! so it can have 24 hours to set up hope that will work !! the next thing would permanently weld it .do u guys have any other option ??? thanks!!
[/IMG]
Old Mar 31, 2013 | 10:29 AM
03sierraslt's Avatar
Sorry all I can think of is Beavis and Butthead.
What bunghole do you have on your headers? A bunghole is a hole in a keg or barrel. 02 Sensor bung?
Old Mar 31, 2013 | 10:40 AM
yes it is
Old Mar 31, 2013 | 10:43 AM
You may have to put a new one on and weld that one closed with a plug.
Old Mar 31, 2013 | 10:45 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Any exhaust shop can weld in a new O2 bung for you, and weld a plug in place over your stripped out bung. It's a quick & easy job for them.
Old Mar 31, 2013 | 10:46 AM
is there any way to replace the bung with a new on !!
TIM Z's Avatar
11 sec. Truck Mod
Can you run a tap in it ? Is there enough material left ?
Old Mar 31, 2013 | 10:47 AM
the problem is no will touch my truck because i have no cat's on it ???? dont make no since!
Old Mar 31, 2013 | 10:48 AM
did the tap !!
Old Mar 31, 2013 | 10:50 AM
if i did that how could i make up the difference of the 02 sensor !!
