Built 6.0- How Much Nitrous?
Old Nov 7, 2007 | 07:34 AM
  #21
sprayed8's Avatar
parish, you sem to be getting plenty of power out of your 5.3, would a 5.3 with all the same mods i was thinking of or 6.0 be able to to keep up if it had a big cam. i'm asking because i'm wondering if a more aggressive 5.3 would have beter fuel mileage.
Old Nov 7, 2007 | 04:12 PM
  #22
parish8's Avatar
single digit dreamer
not sure. i think on a boosted set up you can nearly the same hp with any of the stock motors. 4.8/5.3/6.0 all good for 600+rwhp with a good tune and the smaller the motor the better the mileage.
on a nitrous motor i dont know if all of the motors would get near the same hp level.
Old Nov 7, 2007 | 07:26 PM
  #23
sprayed8's Avatar
both nitrous and boosted motors wok on the same principle of simply forcing more air into the engine so i would think what goes for boost will also go fo nitrous but i'm not sure either. anyone else have a take on this.
Old Nov 7, 2007 | 07:30 PM
  #24
parish8's Avatar
Originally Posted by sprayed8
both nitrous and boosted motors wok on the same principle of simply forcing more air into the engine so i would think what goes for boost will also go fo nitrous but i'm not sue either. anyone else have a take on this.
on a stock 6.0 i would feel prety comfortable with a 200shot. not so sure i would try a 200shot on a stock 4.8 but yea it would probably take it just fine.
Old Nov 7, 2007 | 07:31 PM
  #25
Spoolin's Avatar
GFYS and STFU
Well if this holds true then I don't think what holds true for boost holds true for nitrous...
Originally Posted by Derek @ EDO
Nitrous loves high compression!
When i was going to build my nitrous motor i was looking for 11:1
Nitrous likes high compression
Boost loves low compression. Build it for what you want because they seem to require different parameters.
Old Nov 8, 2007 | 11:59 AM
  #26
sprayed8's Avatar
i was thinking more along the lines of maximum power output. i guess i should have said, since i'm looking to build a motor with decent fuel economy, can a 5.3 with a more agressive cam, bored to like a 383, handle as much spray as a 6.0, make similar max hp, but give me better fuel mileage?
Old Nov 8, 2007 | 01:15 PM
  #27
Tootall's Avatar
i was thinking more along the lines of maximum power output. . .
decent fuel economy, . . .
a more agressive cam, . . .
handle as much spray as a 6.0, make similar max hp, . . . .
buy a diesel
Old Nov 8, 2007 | 02:23 PM
  #28
sprayed8's Avatar
wow your no help
Old Nov 8, 2007 | 02:38 PM
  #29
Tootall's Avatar
wow your no help
do a 6.0 with a 02+ Z06 cam, + STS . . . . 500HP
Old Nov 8, 2007 | 03:27 PM
  #30
Spoolin's Avatar
GFYS and STFU
If you want fuel economy go with the set-up with the smallest chamber size. 6L(364) is better on fuel economy than a bored and stroked (383) and a 5.3L will trump them all. Do what Tootall suggests, proven and simple and good fuel economy, and spray a little for when you wanted added power. Spray shot is doubled when in boosted applications, from what I understand, Parish would know more as he sprayed on 18 lbs 1/4 mile runs.
simman22
Jan 21, 2017 10:27 PM
turbo6c3
Oct 5, 2015 06:11 PM
Mark_k
Oct 1, 2015 11:17 PM
DrX
Sep 29, 2015 04:31 AM
gavin2005
Sep 13, 2015 09:04 PM
