Building a proper exhaust system
Old Sep 4, 2009 | 09:38 AM
Oldcrow's Avatar
Default Building a proper exhaust system
Will opening up the exhaust (free flowing) too much hamper low end torque/drivability?
Or is a certain amount of backpressure needed.
I'm particularly interested in how backpressure would affect my 05 Suburban 2500 6.0L
Old Sep 4, 2009 | 02:32 PM
03 BLACKOUTSSS's Avatar
Opening it up will help a little bit, to an extent, then it will start to hurt things. Are you talking about just a catback, or a full setup, LTs off road intermediate pipe(s), etc...?
On my 6.0, I am running a full 3" system, from the collectors to the merge after the stock muffler. I stepped it up from the stock manifolds (going to LTs typically hurts TQ just a little, but HP gains offset that). My stock intermediate pipes were 2.75", so going to 3" isn't that big of a jump. Plus I have a cam that makes a pretty good amount of TQ, so I can't tell you if the move to 3" affected anything. As for drivability, you'll be fine.
Old Sep 4, 2009 | 03:45 PM
Mangled03gmc's Avatar
Baltimore Whore
You want to keep a lil bit of back pressure on a NA setup.. when you start getting into FI is when you want free flow, due to the chambers getting stuffed with fuel,air.
I am sure that a true 2.5 inch dual set up on your 6.0 or a single 3 inch would suffice fine, unless you are making big hp(400+)
Old Sep 8, 2009 | 09:39 AM
Oldcrow's Avatar
I use my rig for recreation. I pull snowmobile/ATV trailers, boats (the toys).
Not heavy stuff, maybe 4000lb.
My previous truck was a 95 Chevy 5.7, this Suburban has way more power but like all of us I want more.
I have installed a set of ARHeaders 1.750 primaries, 3" collectors with cats. System has duel 2.5" pipes going to the muffler. Over the weekend I installed a Magnaflow cat-back which has duel 3" inlet and single 4" outlet.
When shopping bolt-ons I look for things that increase low end torque, figure that should help drivability and MPG empty or while pulling
Since the Magnaflow is a open design I was getting concerned I may have opened the exhaust too much, but all seems to be fine. Truck sounds good.
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
