Building an older LQ4...Have some questions...
Old Sep 4, 2010 | 03:32 PM
JoeGibbSilverado's Avatar
Default Building an older LQ4...Have some questions...
Well I have a 2000 model LQ4 at the machine shop as we speak, its having to go 60 over, so that will make it a 376 correct? I have read alot about the older cranks being longer than the newer ones, and id have to change it out to a 02-up so that i could bolt a 4l60e behind it...question is, im wanting to do a th350 swap behind it, so could i use the longer crank to eliminate having the spacer for the th350/400 swap? thanks guys
Old Sep 4, 2010 | 03:52 PM
MPFD's Avatar
11 Second Truck Club
Yes the longer crank is what you want for a th350 you will just need a different flex plate. Neil Chance makes an excellent converter for LS1 to TH350-400 trans and its not very expensive.
Old Sep 8, 2010 | 02:13 PM
moes04silverado's Avatar
I have year block with the long crank bolted to a 4l60....
TCI has a flexplate that will work for your 350trans though
Old Sep 8, 2010 | 03:15 PM
budhayes3's Avatar
PT's Slowest Truck
How'd you do it, custom torque converter?
Old Sep 8, 2010 | 03:34 PM
MPFD's Avatar
Thats how I did it...
Old Sep 8, 2010 | 04:36 PM
well i dont have the balancer or the flexplate off the longer crank, but i do have the balancer, flexplate, and newer 6.0 crank out of a 04, just gonna use that, and the adapter to put a th350 behind it, thanks for the help fellas
lxcoupe
Sep 6, 2017 08:24 AM
6.0l RST
Nov 23, 2015 11:30 AM
MA$TER_E
Sep 9, 2015 03:14 PM
God Made Chevy
Sep 4, 2015 12:29 AM
LT-1 SS
Sep 3, 2015 07:31 AM
