building a 5.0 305
Old 08-10-2006, 01:45 PM
If it is a 87+, what kind of injection do u plan on using? I'm hoping multiport. Idk about multiport, but for tbi and LT4 hotcam is supposed to do pretty nice in them.
Old 08-10-2006, 03:26 PM
J$Money's Avatar
if i can get the money i would like to use the injection from the 93-97 camaro if not just the TPI injection that it came w/. from what i'm told it was throttle body injected so i'm not quite sure what to go w/. hopefully the fact of it having a throttle body can help someone determine what year range it is.
Old 08-10-2006, 05:01 PM
J$Money's Avatar
aight guys and gals how does this sound............
block:cast iron
c-rods: stock 5.7"
pistons: forged steel flat tops
crank: forged steel 3.48" stroke
heads: gm L31 vortec, spring upgrade for hydro-roller cam up to .570" lift
cam: LT4 hot cam 525/525" lift w/ 218/228 degree @ .050" duration
valve train: 1.6 rockers, beehive spring up grade
ignition: ngk plugs, 10mm wires, msd distributor
induction: TPI setup or 93-97 camaro setup
exhuast: LT headers, cutouts, H-pipe, borla mufflers
how does that sound to you guys. any suggestions, changes, flaws or anything like that?
Old 08-11-2006, 08:32 AM
It's more than likely an '87+.........Good luck with getn ne decent power from it if it's a TBI. TBI S U C K S when it comes to making good power, unless u got deep pockets. Thats one of the reasons I didn't do anything to the motor in my bird other than an intake. Your better off goin carb if u want more than 250 or so horses.
Old 08-12-2006, 01:56 AM
J$Money's Avatar
good thought but how would gas milage differ w/ a carb.
Old 08-12-2006, 08:04 AM
PT's Slowest Truck
budhayes3's Avatar
There's a reason you can get a 305 for next to nothing...it's not really a desirable engine, especially when you can get a 350 so cheaply, or with some more cash, build a 383. If I was going with an older gen SBC, I'd build a 400 block to 406 myself. Every car that I've ever had with a 305 (or 307 for that matter...early 70's chevy), has been pulled in lieu of a 350 and I basically just took the 305 block staight to the scrap yard. On my last MonteSS, the 305 block was perfect, but I still pulled it for a 345hp ZZx crate engine...I was so much happier. The extra cubes really respond well to the numerous cam and head combos out there...Edelbrock has set-ups that include cam, heads, carb, etc, all matched.
Old 08-12-2006, 11:44 AM
J$Money's Avatar
yea i feel ya on that. i would love to build a 400sbc but buying the blocks are out rageous. the price that i will have to pay for the block and a few parts to go along w/ it will be nothing of what i would have to pay for just a 350 block along. that's why i'm looking into this 305 block. and on top of that it will be a fun project for me.
Old 08-12-2006, 12:54 PM
SS_bnoon_SS's Avatar
Do NOT do TBI. I'm not saying that people haven't done well with it (on thirdgen.org, a third gen F-body site, TBI has quite a following), but TBI owners go through a LOT of headaches to get their results. You would do much better with a TPI multi-port from '87-'92.
The '93-'97 you mention would be an LT1 intake swap, drilled/modified for use with a distributor. Several of the thirdgen.org members have done well with that swap using stuff they've modified themselves, or parts from lt1intakes.com (used to be owned by John Milican, but I think he sold out to another member there). Unless you have some nice fab skills, stick with a prepepd intake from that site.
Old 08-12-2006, 02:37 PM
PT's Slowest Truck
budhayes3's Avatar
How about building a Tuned Port sbc? I'm sure that you could could piece the parts together through ebay for not alot of coin.
Old 08-12-2006, 11:36 PM
J$Money's Avatar
yea tha TPI sounds like a good plan but what i'm most concerned w/ is the hastle to get all the computers and stuff programmed or what not. what all do i have to do as far as computer wise to run a TPI set up. and i plan on running a stick tranny so what computer preparations will i need?
Quick Reply: building a 5.0 305
