Broken Tranny?
Old Oct 16, 2003 | 05:13 PM
AKZ71's Avatar
Default Broken Tranny?
Well, I think my tranny just gave up the ghost. Truck will still move but it feels like not much longer. Whenever I jump on the throttle it just revs until it hits the limiter. First to second shift at quarter throttle holds until about 5k before it shifts. Any ideas on what may be broken?
Old Oct 16, 2003 | 08:20 PM
Hit Man X's Avatar
Default Re: Broken Tranny?
Is it low on ATF maybe? Have you tried changing the fluid? Your intermediate servo's O-ring may have come off not applying pressure to the band...
Judging by your mods in the sig...it doesn't sound like you smoked it unless it has a ton of miles on it.
ALSO>>> Once in 2nd gear, how does it hold? You should still have 3rd right? If you don't have 2nd or 4th it is the band or servo.
Old Oct 16, 2003 | 10:54 PM
AKZ71's Avatar
Nope ATF is good. Third and fourth both seem to work well except in third at around 70 the RPM's just keep climbing more than they should. Seems to be an awful lot of slipping going on in all gears. I dropped it off at the dealership. Should find out soon what broke.
Old Oct 16, 2003 | 11:05 PM
Hit Man X's Avatar
Heck your pump could be bad also...it is really hard to tell you what the problem is being so far away. Hope I helped. Is your truck still under warranty?
Old Oct 17, 2003 | 02:56 PM
AKZ71's Avatar
Yep still under warranty. Squeaked it in with 725 miles to spare.
Wolftrk99
Dec 3, 2015 08:12 PM
gmcyukon
Oct 3, 2015 11:03 PM
Velocity1
Oct 2, 2015 08:01 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 06:27 AM
