Broken Manifold Bolts??
Old Jan 30, 2013 | 06:25 PM
  #21
charcold-bowtie's Avatar
BG In-force is the oil I would use. We removed multiple bolts from a tractor manifold by hand with it lol.
Old Jan 30, 2013 | 07:03 PM
  #22
fix-it man's Avatar
Keep in mind that if you have a firmly stuck header bolt broke off flush in the head, it most likely cannot be removed.
Instead the easiest way is to drill out the center of the broken bolt and re-tap it to a smaller size with a bottoming tap. I had to do this during my header install, and ended up making it 1/4" instead. You are doing the opposite of a heli-coil basically.
Old Jan 30, 2013 | 07:14 PM
  #23
03sierraslt's Avatar
If its broke off flush then center a nut over it and weld the bolt stud to the nut, use a nut with a smaller inner diameter then the outer diameter of the stud so you don't damage the head.
zblee
63
Jun 10, 2023 01:25 PM
jfuegner
Dec 22, 2016 03:47 PM
JFortner5
Aug 20, 2015 06:13 PM
4B11T
Jul 13, 2015 03:48 PM
