Broken inner spring
Old Aug 30, 2011 | 03:22 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by Atomic
and everyone hates on the patriots....
Originally Posted by Holty
AND the Comp's
Everybody has bad batches once in a while.. Lol.
That cam is nit huge, but is kinda big.. What's the max lift for the springs? I would say more then less that would be the problem....
Old Aug 30, 2011 | 03:27 PM
smokeshow's Avatar
Mod with training wheels
Springs are good for .675, probably a bit less on a boosted application.
Old Aug 30, 2011 | 08:01 PM
smokeshow's Avatar
Just purchased new springs to see if i have a "weak" spring or something. basically just grasping at straws and throwing money/parts at it. i have no clue....
Went down to the local Orielly's to have my battery tested. Checked good on the scanner, so I pulled it out and had them check it on the machine inside. Came out good again. Frustrating.. Picked up a compression tester, will try that when the engine cools a bit. Also pulled up the fuel rails and turned the key on to prime the pump...no leaks. Probably try coil packs later... Have you checked the battery on your truck?
Old Aug 30, 2011 | 08:06 PM
GMCtrk's Avatar
I would get PAC doubles, but that's just me.
I have that same cam, with PAC springs rated to .600 lift \, and they're doing great (not apples to apples given your boost, of course) - point being, I think PAC makes great springs.
Old Aug 30, 2011 | 08:11 PM
smokeshow's Avatar
I think everyone has their preference. I've heard dirt on all brands, so Matt at TSP recommend these. Either way I doubt a broken inner spring will cause an idle misfire. Unless it broke at high RPM and toasted the exhaust valve. That would suck.
Old Aug 30, 2011 | 08:58 PM
smokeshow's Avatar
Isolated it to bank 2, passenger side.
That O2 sensor starts to go lean at full boost, so some oxygen is creeping out.
Old Aug 30, 2011 | 10:05 PM
Atomic's Avatar
I have a gauge for that
Funny, my log of when my piston melted looks similar....
Old Aug 30, 2011 | 10:10 PM
smokeshow's Avatar
Notice the 0 KR with stock sensitivity though...
Old Aug 30, 2011 | 10:33 PM
chevymec's Avatar
Do a leak down test and see what it says. Most times when I encounter a misfire at idle it involves a valve problem.
Old Aug 31, 2011 | 03:24 AM
Spoolin's Avatar
GFYS and STFU
I'm keeping my fingers crossed too cuz I have a misfire at upper rpm's hence why I shift at 4500 and keep the boost at 4psi for right now!
