Broken header bolts
Old Oct 2, 2007 | 11:50 AM
tx_tygr's Avatar
Default Broken header bolts
What are you guys doing to remove broken header bolts from aluminum heads? I'll be installing my LTs soon and want to be prepared with the right tools should I need remove any. My truck has about 40000 miles and I'm hoping the stock bolts with a good soak of penetrating oil the night before come out OK.
Old Oct 2, 2007 | 02:54 PM
truckmann's Avatar
I had 3 with the heads broke off on my 100K mile engine and they came out easy enough with a pair of vise grips. The bolts don't really seem to get stuck in the aluminum heads like they do iron heads. If they aren't broken already I think you should be able to get them out just fine.
Old Oct 3, 2007 | 08:56 AM
Tootall's Avatar
drill it out. Start off with a small bit and work your way up, and "try" to make it as straight as possible. Look for a bolt extractor kit. Usually it comes with a bit, and a tap that you hammer in. If you break the tap, your screwed. While you're drilling, use some WD40 or oil, anything but water to keep it cool.
zblee
63
Jun 10, 2023 01:25 PM
chopperloco
Jul 10, 2016 10:45 PM
mr03silverado
Jul 26, 2015 01:05 PM
4B11T
Jul 13, 2015 03:48 PM
