Broken Exhuast Manifold Bolt Removal?
Old Nov 5, 2010 | 06:29 PM
HoveyBayou's Avatar
Default Broken Exhuast Manifold Bolt Removal?
Hi Everyone,
It appears I have the typical exhuast manifold bolt breaking off in the head malfunction. Four of them were that way before the manifolds were removed. It is at a local shop now, they have tried a variety of bolt extractors and 90 degree drilling, but nothing seems to work.
The problem is one is all the way in back near the firewall, making access to the broken bolt impossible. Is there anything we can try short of removing the head? The shop says it shouldn't leak with that missing bolt?
Thanks in advance!
2000 Gen III 5.3
Lamonte Performance Parts LTs
Old Nov 5, 2010 | 06:43 PM
mhotrodscooter's Avatar
Driver side? If so jack up or lift up. Remove tire & enter fender. Grab the welding machine (mig works best) build up the broken bolt till it's poking out the head a little then , weld a nut to that.. Let cool then try & back it out.. May take a couple of tries to get it..
Old Nov 5, 2010 | 06:48 PM
HoveyBayou's Avatar
Ok thanks! Yes driver side, the bolt is broken off flush with the head. They were hesitant to try with the aluminum heads.
Old Nov 5, 2010 | 07:12 PM
jrplz's Avatar
Thumbs up
ok guys Ive used this and it worked !!!!!!!!!!!!!
just call cutomer service and ask them for kobalt drill bits
tell them the size of the bolt etc. trust me it works just be very carfull not to brake the bits (they have a 30 day garante your money back)
Old Nov 5, 2010 | 07:14 PM
jrplz's Avatar
ups sorry here is the link
click
http://www.tightfittools.com/riganat.html
Old Nov 5, 2010 | 08:07 PM
bennettracing's Avatar
I removed the rad support bolts and cab mounts, then jacked up the leftside for clearance. I used an angle grinder to drill a 1/8 hole in the bolt then used a dremel tool with an ext and a tungsten bit to split the bolt cleaned threads and has been fine since, good luck!!!!!!!!
Old Nov 5, 2010 | 08:08 PM
KleenHall's Avatar
i used the weld method, but weld a washer to the bolt then a nut to the washer
but mine was out of the truck
zblee
63
Jun 10, 2023 01:25 PM
signguy62
Jul 27, 2015 03:42 PM
08nali
Jul 23, 2015 11:39 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
