Broken dual valve spring removal
Old Jun 7, 2018 | 10:28 PM
Wolftrk99's Avatar
Default Broken dual valve spring removal
Any insight would be amazing i have dealt with single springs breaking before but this is my first dual spring that has broken! i have the trickflow on head compressor for the l92 heads, problem is when i install it and try to compress the springs it pops the valve open and ***** the top plate at an angle, dont want or need to drop a valve at this point... need to get this spring swapped out and tbe yukon out of there tomorrow.... just need to be able to bring it home at this point... thanks in advance
Old Jun 7, 2018 | 10:31 PM
FFDP's Avatar
Pressurize the cylinder with air so the valve can't drop or fish some small rope into the cylinder and turn the engine over by hand so it pushes up on the valve to stop it from falling.
Old Jun 7, 2018 | 10:34 PM
Wolftrk99's Avatar
Had about 90 psi in the cylinder, should i put more in?
Old Jun 7, 2018 | 10:36 PM
R U Jimmy Ray's Avatar
Thumbs up
Rope trick works every time!
Old Jun 7, 2018 | 10:42 PM
Wolftrk99's Avatar
Ok ill find some rope to fish into the cylinder, thanks guys!!
Old Jun 7, 2018 | 10:48 PM
1FastBrick's Avatar
Custm2500's Rude Friend
90... Bump it up to 120 at least... more if you got it.
Old Jun 7, 2018 | 11:10 PM
Wolftrk99's Avatar
Thought about just putting straight line pressure to it, trying to find tdc on that cylinder, to at least catch the valve if it does drop....i just wish i had the time to pull the timing cover and swap the tensioner out while i was doing this, but this is the only reason i didnt walk out today when i saw my paycheck!!!
Old Jun 8, 2018 | 03:26 PM
Atomic's Avatar
I have a gauge for that
Put that piston at TDC, the valve wont be able to drop very far.
Old Jun 8, 2018 | 03:33 PM
2002_Z28_Six_Speed's Avatar
how much lift were you running?
Old Jun 8, 2018 | 04:18 PM
Wolftrk99's Avatar
.612/.585 vvt cam if i remember correctly
