broken bolt help
Old Oct 15, 2007 | 12:13 AM
swampthing's Avatar
Default broken bolt help
I broke the driver's side bolt, closest to the rear on my header install. I put it all back together thinking that there may not be a leak, but I was wrong.
I am going to go back and take out the bolt, but it is broken off flush with the head. Does anyone have an idea on how to get it out.
If not, can I add a copper gasket on the last exhaust port, on top of the stock exhaust gasket?
Old Oct 15, 2007 | 02:02 AM
TouchOfEvil04's Avatar
gonna need a tap to get it out. Then being that it's on the back side of the motor....hope you don't have to remove the head to get the tap in properly.
I'm sure you can do it but it's gonna be a pain.
Old Oct 15, 2007 | 07:30 AM
Raffman's Avatar
You should start thinking about "plan B" , a thick gasket and plenty of copper silicone.
I broke snap-on easy outs on my motor and it was sitting on the floor,in the truck is going to be a bitch. It's such a small bolt and you have to drill a perfectly centered hole and the dia. of the easy out is so small it's very easy to snap it off. Goop it up and forget about it until you pull the heads for port work and let them get it out.
Old Oct 15, 2007 | 11:51 AM
krambo's Avatar
I have used left handed drill bits with a right angle drill in reverse with great success. More often than not, the bolt came out before I even had to use an "easy out".
Old Oct 15, 2007 | 06:12 PM
erronisme's Avatar
sometimes they will break so that you can use a pick on an edge, sometimes they will unscrew, sometimes they wont.
If its flush, you can weld a nut on it.
You can also drill a hole in it and use a bolt extractor. Hammer the extractor in and dont use too big of a drill bit, and keep the drill bit as straight as possible. You dont want to get into the threads in the head.
Old Oct 15, 2007 | 08:37 PM
Stoichiometric's Avatar
Same experience here. Buy some LH bits and center punch that bolt if you can.
Old Oct 15, 2007 | 08:51 PM
Flyer's Avatar
I agree. LH drill bits are good.
Old Oct 15, 2007 | 09:27 PM
colekill's Avatar
KickinAssAndTakinNames
Same problem with me last one back on the driver side. when i went to take the stock manifold off, that bolt head was just gone sheared off. I just live with the tick.
Old Oct 15, 2007 | 09:43 PM
dirt track racer 81's Avatar
when i was doin my header install on my 5.3 a while back i noticed the back bolt was already broke..i said **** it..dapped quite a bit of black rtv on it and if it leaked oh well..but actually it didnt leak at all
Old Oct 15, 2007 | 09:50 PM
Phantom's Avatar
11 Second Club
my back bolt isn't even in on the driverside...no gasket maker or anything
