Broke a tap in the head.
Old Aug 13, 2008 | 01:16 AM
sikchevy's Avatar
Default Broke a tap in the head.
So I win boner of the month. I over torqued a header bolt and messed up one of the threads inside the head. I went to put a new heli coil inside the hole but while using the tap i snapped the **** in half. Dont know how just did. Probably not enough lube, so either way, I have another set of stock heads and wondering if it is ok to just replace the one side? What do you guys think?
Old Aug 13, 2008 | 01:24 AM
viciousknid's Avatar
Where's the Beef?
as long as both heads are the same it's fine.
You could probably even get away with missing just 1 bolt
Old Aug 13, 2008 | 01:44 AM
sikchevy's Avatar
I would just leave it like it is but the sound of the exhaust leak is driving me up the wall!!
Old Aug 13, 2008 | 06:42 AM
Moddoo's Avatar
If you are careful, you can drill through the broken tap with a carbide drill bit.
you may damage the threads a bit while working on it, but the helicoil won't care.
Honestly, it may take you an hour of careful work, but it saves the head.
Old Aug 13, 2008 | 06:50 AM
Grumpy5.3's Avatar
I know for a fact that matco make a tap removal tool. it has 4 little fingers guess you would call them you slide it in there and presto it wil pull it out...
Old Aug 13, 2008 | 07:44 AM
skeet's Avatar
bro that sucks, i know how ya feel, done it a few times myself, for something to be hardened stell an to break so easy, just plain sux, then again it depends on what brand taps you use.
yep they sure do i have one, and works well, also if you dont wanna buy a tap use a very small pointed punch, i would do this with the head off, and try and loosen the broken tap, by tapping it cc. drilling a tap out is a bitch, i wouldnt even attemp it, you'll end up ruining the head more then likely
Old Aug 13, 2008 | 08:06 AM
Big Red Truck's Avatar
11 Second Truck Club
You cannot drill out a tap. However you can take a small punch and break pieces of the tap off until you get it all out. Patience is a virtue with this procedure, but it can be done with success.
Old Aug 13, 2008 | 08:12 AM
Moddoo's Avatar
I offered my advice based on experience.
I have drilled taps with carbide drill bits before. It works.
Old Aug 13, 2008 | 08:33 AM
sonoma43's Avatar
get a carbide punch and smack it fairly hard, if that doesnt work get a carbide 1/4 inch endmill and a high speed drill and little by little it will break away leaving the threads fine and dandy if your careful.
Old Aug 13, 2008 | 08:51 AM
Wilde Racing's Avatar
How do I change this text
I've used a tap extractor like Grumpy5.3 said, and a I've broke them to pieces. If you don't have a extractor breakingit in pieces is the easiest way. those taps are so hard they shatter pretty easy....
