Break in time for cam?
Old May 24, 2008 | 10:46 AM
00ChevyScott's Avatar
Wearin' da big hat
Default Break in time for cam?
I haven't really heard much on this subject. Is there much of a break in time for a cam swap (cam, springs, rods)?
Old May 24, 2008 | 10:56 AM
7845's Avatar
Banned
no break in but would try and give the springs a few proper heat cycles
Old May 24, 2008 | 04:57 PM
chevyguy7802's Avatar
+1 on that!
Old May 24, 2008 | 05:17 PM
no break in....but i'd still change your oil after 500miles and maybe 1000miles just to make sure there's not shavings that might get in your pump or anything.
Old May 24, 2008 | 07:21 PM
black4.8's Avatar
let the springs go through 2 heat cycles, than give her hell.
Old May 24, 2008 | 07:34 PM
fastgmc98's Avatar
only on flat tappet cams which is 20 minutes on initial startup sustained RPM between 2000-3000....I don't think you need to "break in" a roller cam(I NEVER HAVE) I could be wrong but I'm 99% sure!
Old May 25, 2008 | 11:16 AM
05GTO6SPEED's Avatar
what is one heat cycle????
Old May 25, 2008 | 11:27 AM
D_reks{5.3}'s Avatar
just letting it idle for 15 mins or so just to heat things up.
Old May 25, 2008 | 11:51 AM
Wearin' da big hat
ill let it idle to scare the rice away
Old May 25, 2008 | 12:47 PM
black4.8's Avatar
let it get up to full temp and completely cool down is one heat cycle.
