Brand & Part # of electric fans relay kit fot those who wanted to know!
Several guys have asked which one I used when I installed my electric fans so here it is. I got it a Kragans and it's made by Imperial Automotive Products and the part number is 226204, it says "fan controller" on the package. Hope this helps!
Jim
Jim
Thanks Y2K <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Now I just have to find a store around here that sells that brand.
For those living in different parts of the country, this link (Parts America) shows the different store names the company goes by. The part number should be the same in each store.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Advanced Auto Parts in the Northeast. which flex-a-lite fan will fit in our trucks? i maybe interested in this mod
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Flex-a-lite, I'm not sure <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> . I think some guys have posted using 282's or 250's but I'm really not sure. Check E-bay, get some LT1 or LS1 Camaro fans, they'll work and be cheaper than the Flex-a-lites.
Jim
Jim
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Y2K Silverado:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Advanced Auto Parts in the Northeast. which flex-a-lite fan will fit in our trucks? i maybe interested in this mod
Jim </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">are the LT1 or LS1 fans easy to install? did i hear that some use tie-wraps to hold it in place? is the wiring easy? and how much more HP should i see, if any? i'm guessing 5 rwhp at the most, i could be wrong
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">are the LT1 or LS1 fans easy to install? did i hear that some use tie-wraps to hold it in place? is the wiring easy? and how much more HP should i see, if any? i'm guessing 5 rwhp at the most, i could be wrong
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I thought the fans were easy to install and I have basic mechanic skills. The hardest part is getting the stock clutch fan off, the nut can be a bitch <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> . The LT1 fans sit right down in the lower radiator bracket. I made up two brackets to hold the top part of the fan in place, you can use the screw holes that held the top part of the fan shroud. The power gain I felt wasn't huge but it was there, I would say about 5 hp to the tires is a good guess. Every little bit helps and it's not that expensive to do. Look on E-bay for the fans.
Jim
Jim
The things I used are kind of like tie wraps but they are made for mounting things thru a radiator. You push this long piece thru and it goes into a flat round piece and it clicks until its tight then cut off the excess. However they are not as strong as tie wraps so I used 6 of them just to be safe. They are made by Hayden and are 5 bucks for a pack of 4.
