Brake light switch problem
Old Apr 4, 2012 | 11:32 AM
Ferocity02's Avatar
Default Brake light switch problem
I've had this issue ever since I've owned the truck. If I push down the brake pedal, the brake light switch will click and the brake lights will turn on. Then when I lift the pedal slightly, maybe 1/4-1/2", the brake light switch will click off but the brake will still be engaged. Is this normal?
It's annoying because I'll be braking up to a light, then when I'm stopped I'll let off the brake slightly, then the brake lights will turn off but there's enough braking power to keep me from moving, begging to get rear ended by some grandma.
Old Apr 5, 2012 | 12:05 AM
Blown06's Avatar
8 Second Truck Club
There is a spring inside the switch housing. It's all made out of plastic so its likely that there is some damage or the spring is out of place. Best bet is to probably buy a new switch.
ARC
57
Feb 21, 2022 10:54 AM
Corvette454l88
Sep 1, 2016 01:24 AM
97aztecgt
Aug 13, 2015 02:11 PM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
