Brake controller wiring on a 2003
Old Apr 24, 2003 | 08:02 PM
Scott95TA's Avatar
Default Brake controller wiring on a 2003
I picked up a harness today for my brake controller.
In an earlier post someone stated I needed to use the brown wire for the brake switch.
I ordered the 2003 harness, it has 5 wires on it, came with a 40 amp fuse for the underhood fuse bax and a 7-wire to 4-wire adapter. Not bad for $25 from the dealer.
DK BLUE -- Trailer Brake controller switched output
RED -- Fused Trailer Brake Controller Battery feed
BLK -- Brake Controller Ground
LT BLU -- Vehical Stop lamp switch to brake controller
BRN -- Brake controller illumination
Do I have the 2003 harness? I think I do. If so I guess I do NOT need to use the brown wire for the brake switch, right?
I just want to be sure not to blow anything up.
Old Apr 25, 2003 | 08:17 AM
Seeing Red Again's Avatar
Default Re: Brake controller wiring on a 2003
Don't know, but let's TTT for ya. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 25, 2003 | 08:46 AM
one03sierra's Avatar
Formerly one92rs
i have 2002 harness and it says the same
dark blue--brake out
red--fuse bat+
lt blue--brake signal
black--brake ground
brown--illumination
i did not hook up the brown wire on mine 2002 silverado.
<img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Apr 25, 2003 | 09:03 PM
Scott95TA's Avatar
Thanks for the input guys! I wired it all up and everything work fine. I just did not use the brown wire( controller illumination).
Thanks again!
thunder550
Oct 8, 2015 04:53 PM
nickpc82
Aug 30, 2015 09:18 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ketis
Jul 23, 2015 12:37 PM
