Bought a truck and the tq converter is not locking, any idea?
Old Sep 25, 2015 | 01:31 PM
Cammed4ever's Avatar
Default Bought a truck and the tq converter is not locking, any idea?
Hey guys, as the title says, I bought a 2006 silverado 2500hd 6.0 4L80..
It has 4.10's as factory and @65mph its doing a bit over 2550rpms at 4th gear with 32" tires, the snap on scanner versus or however it's called, its showing the torque converter not locking, and 0 duty at any point or shift.. Anybody had that happen before?
The mechanic even flashed the computer to factory settings and is still doing the same..
Any idea??
Thanks in advance!
Old Sep 25, 2015 | 01:51 PM
smokeshow's Avatar
Mod with training wheels
Any codes?
Old Sep 29, 2015 | 04:04 PM
No codes at all, just the pcm is not sending the lock or unlock signal..
Old Sep 29, 2015 | 04:13 PM
smokeshow's Avatar
I don't know if you tune your stuff or someone else, but there are parameters you need to adjust in the tune for misfire detection. They can prevent a converter from locking up...probably where I'd start.
Old Sep 29, 2015 | 04:16 PM
GMC93's Avatar
I thought the only time the tc wouldn't lockup is if the trans wasn't up to temp.
Old Sep 30, 2015 | 03:38 PM
Ken in AZ's Avatar
It could be the o-ring on the input shaft took a crap, that can cause the TC to not lock up and not show on a scanner.
cams 98 silverado
Jul 31, 2015 07:36 AM
04450r
Jul 24, 2015 01:58 AM
MileHighSierra
Jul 22, 2015 11:19 PM
black6spdz
Jul 16, 2015 01:32 AM
