Bore a 4.8L?
Old Dec 11, 2006 | 11:26 PM
StrokerAce03's Avatar
Would it be possible to bore the engine out and keep the 4.8 crank? I've been toying with this idea myself but can't find the correct rods for it.
Old Dec 11, 2006 | 11:40 PM
TURBHOE's Avatar
if i remember right, the piston hieght is the same on the 5.3 as the 4.8 even though the 5.3's are dished and the 4.8's are flat top. meaning you could use 5.7 pistons and stock 4.8 crank and rods. they just used a longer rod to make up for the shorter stroke.
Old Dec 12, 2006 | 08:17 AM
screamingjimmy's Avatar
does anyone know what the compression would be if I bored my 4.8L to a LS1 bore, keeping the stock crank, rods, heads, ...
I think right now stock it is 9.6:1
oh, and flat-top LS1 pistons!
Old Dec 12, 2006 | 11:27 AM
TURBHOE's Avatar
should be around stock ls1. well it depends on what heads you go with too.
Old Dec 13, 2006 | 02:16 AM
PappyDan's Avatar
Tribe Shaman
compression should be higher then the LS1.
the 4.8 heads have a much smaller combustion chamber.
guess im kicking around the same idea as a few of you are too.
right now im looking at droping in a 4.8 crank in to a 5.3.
with the smaller rotation and the shorter 5.3 rod, compression should really drop.
add a set of 317 6.0 heads to drop it more.
valve clearence should be more then enough for any cam.
just wondering what the max boost level will be before any knock shows up.
Old Dec 13, 2006 | 12:18 PM
TURBHOE's Avatar
if you use the 5.3 rods the rotating assy will be too short by over .3" that quiet abit i would think.
Old Dec 13, 2006 | 01:28 PM
treyZ28's Avatar
Originally Posted by screamingjimmy
what if a guy took a used iron 6.0L block, bore it to 4.030, throw in a 4.8L crank and rods, build a little high revver.......
has it ever been considered? I guess that a guy would be better off to go with a 6.0L at that point instead of "de-stroking" an engine!
there is no replacement for displacement!
Your limit is going to be valvetrain WAY before bottom end.
If you had a solid roller revvign to the limitations of piston G's- you might have a case.
Old Dec 13, 2006 | 01:30 PM
PappyDan's Avatar
Tribe Shaman
yeah it is, but as you know, the lower the compression, the higher the boost level.
Old Dec 13, 2006 | 10:46 PM
StrikeZero's Avatar
Hmmm . . . I was thinking of builing up a high revving 4.8 for my AutoX car . . .
4.8 = $800
LS anything = $1800+ (At least in my neck of the woods)
A crazy wild cam in a 4.8 @ 7200 rpm w/ T56 and 4.44 be a dream 2800 lbs car
Old Dec 17, 2006 | 09:40 PM
regency's Avatar
what if you used the 4.8 pistons, and 5.3 rods and crank????? would this work and what would it be like
