boost ? on a LQ4
Old Apr 1, 2005 | 04:43 PM
MR.QUIK's Avatar
Default boost ? on a LQ4
Waz running a 5.3 with a whipple 10psi anyway it went out now im running a LQ4 6.0 same whipple but the boost dont hold at 10 it dropes is that normal on my 5.3 it would hold a little better
Old Apr 1, 2005 | 04:47 PM
Your 6.0 is using more of the air your whipple is throwing down its lungs. That sould explain the drop in boost pressure.
If you want a little more bosst from your whipple for your 6.0, then do a pulley change.
Hope this helps a little.
Jim
Old Apr 1, 2005 | 04:50 PM
MR.QUIK's Avatar
well i have the 10 pound pulley but i was thinking going the a 75 shot of nos and leaving the boost there
Old Apr 2, 2005 | 07:22 AM
OUT2WIN's Avatar
Lets try the nitrous out and see for ourselves. Allen said the 6.0 wouldn't build the same boost as the 5.3 did with that pulley. I will ask over on his site.
Old Apr 2, 2005 | 09:52 AM
mine does the same thing, i think. I can hit 11lbs of boost, but, it won't stay there. As the rpm's go up and the trans is preparing to shift, the boost drops slowly and so does my fuel pressure. Normal?????
Old Apr 2, 2005 | 09:58 AM
MR.QUIK's Avatar
I quess that's normal then cuz my fuel psi drop's 2 so then i quess it's time 4 NOS
Old Apr 2, 2005 | 10:03 AM
MR.QUIK's Avatar
Hay DanaliHD r u running stock fuel
Old Apr 2, 2005 | 10:08 AM
normally i run 93 octane. I did run 100 octane the other day. No difference in KR. The truck felt a little stronger though.
Old Apr 2, 2005 | 10:13 AM
MR.QUIK's Avatar
Sorry I ment stock fuel system
Old Apr 2, 2005 | 10:32 AM
NOPE, i just added an inline fuel pump. same one magnacharger uses. No difference.
natejk
Nov 15, 2016 08:05 AM
Knightcrawler
Jul 20, 2016 03:29 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
bisqikss
Sep 8, 2015 03:35 AM
06murder
Sep 4, 2015 03:54 PM
