blowing header gaskets? HELP!
Old Aug 23, 2005 | 11:33 PM
Phatchevy's Avatar
Default blowing header gaskets? HELP!
hey yall my brother has a 1998 suburban w/ a 5.7L and is STOCK EVERYTHING, SUCKS!!! anyways, he keeps blowing the header gasket and he doesn't know what do to about it. i'm sure he is buying the cheap autozone gasket but could that be the problem? if so what gasket should he get? i think he has about 100,000 miles on it. he never races or goes off roading it's just a grocery getter and road trip vehicle. anyways besides buying a new suburban (which is what i suggest) what should he do? what is causing this problem? thanks....
Randy
Old Aug 23, 2005 | 11:56 PM
ap2002's Avatar
he needs to buy the OEM gaskets from the dealership.... some aftermarket gaskets are worthless believe me I changed them out twice before I found out to just buy the OEM gaskets...
Old Aug 24, 2005 | 12:03 AM
gonzo 6.2's Avatar
Seems the 5.7 vortec is a machine fit stock manifold.You said it was bone stock?Bone stock with headers added or bone stock with stock OE manifolds?
Old Aug 24, 2005 | 08:51 AM
Old Aug 24, 2005 | 08:27 PM
Mangled03gmc's Avatar
Baltimore Whore
what kind of headers are they. Is the flange thick or thin. I am with the other guys go with an oem gasket. Make sure you start from the inside out when you tighten the bolts. Good Luck
Old Aug 25, 2005 | 04:53 PM
Phatchevy's Avatar
damn i feel like an idiot. i meant to say head gasket. sorry about that. i actually talked to my brother today and he says that there is antifreeze leaking down on him. now is that a head gasket or intake problem? my brother is pretty cheap and he said that he is probably going to just keep filling it with antifreeze/water. He's a little lazy and cheap when it comes to car repair.
Old Aug 25, 2005 | 04:58 PM
Baltimore Whore
Get a nice set of fel pro gaskets.start from the center and work your way out when tightening the bolts.
Old Aug 25, 2005 | 05:51 PM
budhayes3's Avatar
PT's Slowest Truck
The intake manifold gaskets are a common failure on those trucks...I believe the right rear corner is known to leak...
Old Aug 26, 2005 | 09:10 AM
gonzo 6.2's Avatar
You said he "keeps blowing the gaskets" with your second remark i gather he has yet to ever have touched it.Common is the intake gasket to fail.
flatblack83
Jan 3, 2026 07:10 PM
chopperloco
Jul 10, 2016 10:45 PM
blown02408
Feb 24, 2016 04:50 AM
MS79
Aug 29, 2015 12:24 AM
mr03silverado
Jul 26, 2015 01:05 PM
