blower only ET reductions, whipple, radix, ati.......
Re: blower only ET reductions, whipple, radix, ati.......
Why not run a Radix intake and intercooler with a 3300R Whipplecharger on a 422 cid iron block with ported 6.0 heads.I think you would be looking at 1000hp potential.
Hit man i brought something up like you are talking about a while back. i figured get a blowzilla and use all the radix stuff but just reolace the eaton compresor with the kb one. I did a lot of research and figured you could do it with a couple custom parts. Dont think it would be all that hard but also not easy. Any ways for the price you could have a custom turbo setup.
Parish8 why not buy the lightest truck you can fabricate a 4 link rear suspension and add a stronger rearend and transmission,that would be easier to run 10s with and make one heck of a street racer.4200lbs divided by 650hp equals a 6.46lbs per hp while 5400lbs would take 836hp to make the same power to weight ratio.I think with a trip or two to the junk yard the lighter truck would be cheaper too.
Reg cab short bed 4x4
stock-17.0 at 79mph
dual 3" with magnaflows-16.8 at 80mph
ATI-15.3 at 89mph
reduction-1.5 sec, 9mph
Ed wright tq man. removal,
higher shift points, shift kit-14.8 at 92
3000 stall, remove cats,
cutouts, eaton posi,JBA shorties,
CAI, bigger K&N, 4wd launch-15.2 at 90
44lb injectors, edit,
EASE, FJO, 11lb pulley-15.2 at 90
still trying to figure these last 2 times out!!!!!!!
stock-17.0 at 79mph
ATI-15.3 at 89mph
Go for Parish8 I'm the one to talk about building a light weight truck while I drive 5700lb Tahoe.But my Tahoe is proof that you can make 2wd truck hookup,just ask guy in the M3 BMW I outran from a stoplight or the SVT Cobra I beat from a roll.Good street radials and a well setup suspension make all the difference.Maybe one night I'll race your truck for the heavyweight championship,the winner could tow the loser home.No lack of towing capasity here.I've never done things the easy way either.Besides a HD will make one hell of a sleeper.
I didn't run the truck stock but I believe a 2500 Suburban with the 8.1 motor runs somewhere in the high 16s (not the fastest big block on the road).
Current mods to run 14.54 @ 93.43 are -
Whipple supercharger with intercooler. Volant induction, TOG headers, stock catback ( I like it quiet), Direct Hits ignition, custom programming and a 2600 stall Yank converter. Truck weight - about 6800lbs.
I think I can fine tune this a little to get into the lows 14s.
Tom
Parish,
Nice choice in trucks but you should look at a Duramax with allison. One fueling box, one beefed up tranny and custom cold air and you would be into the mid 12's.
