blinking check engine llight
Old Jul 14, 2012 | 04:26 PM
MBishop's Avatar
Registered User
Default blinking check engine llight
Got a 02 6.0 with a blinking cel at higher rpms. It wont get out of its own way. crappy mpg to boot. any ideas ??
Old Jul 14, 2012 | 04:33 PM
greasemykey's Avatar
thats a multiple cylinder misfire i bet. you need to get a OBD computer and check your code first.
Old Jul 14, 2012 | 04:53 PM
1FastBrick's Avatar
Custm2500's Rude Friend
A flashing check engine light is an indication of a misfire. Its flashing to let you know you are damaging the catalytic converters. If The cylinders are not Firing the are not makeing any power. You will need a code reader or a scan tool to read the code for the check engine light.
The code will tell you were to look in order to solve the problem.
Old Jul 14, 2012 | 06:00 PM
SLOWOH1's Avatar
Yup exactly what they said. Mine was Doin this after LTs and ory install. 2 new o2 sensors later I'm good to go
Old Jul 15, 2012 | 10:18 AM
MBishop's Avatar
Registered User
I kinda figured that was the deal . I have checked the codes once before and there wasnt any stored in the pcm .
Old Jul 15, 2012 | 10:30 AM
AndysC3's Avatar
most common are the front O2s. How old are the spark plugs/wires? Anything done to the truck?
Old Jul 15, 2012 | 12:21 PM
1FastBrick's Avatar
If the check engine light comes on for any reason it will record it. Even if the light is no longer on it will store a code in the history.
I am not sure what your using to check the codes, but maybe it is not reading properly. I would take it in to a qualified shop and get a second opinion. Try going some were that offers a free code check. Some auto parts stores offer this feature as well as some of the lube shops.
Not all scan tools and code readers are created equally. Some basic code readers will only show Currently Active codes.
Along with active codes that are currently displaying a check engine light. There are also Pending codes that are about to set that will not cause the light to go on as well as any codes that are no longer actively causing the light to set that will be stored in the history.
tweeder
Sep 18, 2015 11:02 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Stainless Works
Aug 4, 2015 12:56 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
