Biggest cam in a 5.3
Old Jul 7, 2005 | 06:54 PM
  #41
BigBlockChev572's Avatar
Originally Posted by Flyer
Why's that? That short strock would rev to the moon.
Have the issues with the ls2 block been worked out? The knock sensors is what I'm thinking was the issue.
And that it overheats due to smaller cooling passages I think? Flyer, just go with the Magic Stick (A.K.A MS3). hardened push rods. TSP's heads, $1500 for 300CFM @ .600 with PRC dual springs, a 4K converter with 4.10s, with a TH400
Philip
Old Jul 7, 2005 | 07:17 PM
  #42
02sierraz71_5.3's Avatar
Originally Posted by Snake Eater
I get about 125 miles on a full 24.5 gallons in town with the stall and alot of playing. So a whopping 5 mpg.
suddenly I dont feal so bad about my 10 mpg city the 20 mpg highway is nice though we will see what it is with the bigger injectors
Old Jul 7, 2005 | 08:41 PM
  #43
Why Are Yall Wanting To Go So Big With The Cam? You Lose Alot Of Torque And Gas Mileage Ya Right. These Trucks Are Not Real Lite. Imo 560 Lift And Like 228 Duration Would Be The Most I Would Do In These Trucks. Just My 2 Cent Holla At Yall Layta
Seth
Old Jul 7, 2005 | 09:07 PM
  #44
Flyer's Avatar
I don't have a lot to loose in mileage. As it is now, I get 9-11 in the city, and 12 on a good day on the highway.
BBC, no 400, that's not very streetable. I'd have to stick with something streetable.
*coming from someone wanting to put a HUGE *** cam in a truck motor*
Old Jul 8, 2005 | 04:45 AM
  #45
storm5.3's Avatar
13 Second Truck Club
222/224 .566 .568 112LSA here.
Old Jul 8, 2005 | 04:45 PM
  #46
Yes, a MS3 is streetable, but a TH400, are you crazy! Well, I guess a built 4l60E from Team Tripp or so, Slowprocess has the 600HP one from Bernard, and he's not doing too bad .
Philip S.
Old Jul 8, 2005 | 05:27 PM
  #47
Comp Cams XTREME XE-R XER287HR - 238/240 - .605/.609 w 1.7 rocker - 112 LSA
VHP 050-051
DUR @ .004" 298*/ 302*
DUR @ .050" 236*/ 240*
LIFT .600/.600
OVERLAP 78
LSA 112
and some double springs, didnt list when valve float occurs the vhp is a stroker cam and would probably pull well into the 7k rpm range
are you gonna stay with hydraulic lifters? Is this gonna be an everyday still
just some thoughts idle would probably have to be around 1500 Id love to see something crazy like this.
Old Jul 9, 2005 | 11:26 AM
  #48
F8L Z71's Avatar
You're dropping the FI too huh bro? LOL
I'm still on the 226 cam in the Z71 and it made pretty decent power through the 80E. I won't know the final numbers till we get this stupid converter problem fixed then redyno/tune it. Gotta get the friggin thing repainted first though.
On my RCSB I'm going to do the 370ci but up the compression and go more of an N/A and nitrous setup so I'll let you know what we come up with. It won't be a real huge cam though. My guess is it won't break 228dur as I want to be able to smog the truck with this cam in it. I might even go stupid and try to use the stock exhaust system but with dual cutouts in the Y-pipe for racing. LOL
I can't wait to see what you come up with this time. I been busy mackin' on the honeys so if I miss something important you better PM me.
Old Jul 9, 2005 | 01:04 PM
  #49
litreddevil's Avatar
Banned
I Have The 216/220 Comp Cam Not Big Like You Are Looking For But Runs Real Good.like Snake Eater Said,i To Turn My Motor To 7400 That Is My Rev Limit.and I Have Hit The Limiter A Few Times.
What You Are Planing To Go With You Want To Look Into The Dual Springs.regardless On The What Rpm You Are Wanting To Shift @and If You Stay Under 600 Lift Still Go With Duals Because Of The Rpms.
Old Jul 11, 2005 | 12:23 AM
  #50
Flyer's Avatar
If you spin a 216/220 up that high ... you're loosing so much time in the power band there. That's what Ive got in mine now and it's good for about 6600 and that's tops.
