Biggest Cam
Old Jun 11, 2010 | 08:43 PM
Oldtoad's Avatar
Default Biggest Cam
What is the biggest cam that I can put in my DD without changing the converter or gears. I only use the truck to go back and forth to work but sometimes I will haul a load. I like to get in the 13's but you can see how heavy I am. I also like to keep the RPM's around 6000. I will be adding LT's and later L92 heads. I have stock tires.
Old Jun 11, 2010 | 09:13 PM
low2001gmc's Avatar
a tr220 would work well with a stock converter and 3.73s and you can limit your rpms to around 6k. since not a high lift/high rpm cam, i would think 243 heads would work better while also rasing your compression a bit.
Old Jun 11, 2010 | 09:20 PM
m3srt's Avatar
Banned
what he said >^
Old Jun 11, 2010 | 09:34 PM
dirt track racer 81's Avatar
I gotta stock conveter with my cam in sig..lol I have 4.56s though.. it drives damn near like a stock truck..
Old Jun 12, 2010 | 05:51 AM
supercharged680's Avatar
dirttrackracer81... whats ur quartermile?
Old Jun 12, 2010 | 07:32 AM
Havent had it to the track. I dont have a trans that can hold up.. thats why I got a stock converter in it.
Old Jun 12, 2010 | 02:50 PM
Jake99's Avatar
I agree with the 220r cam, at the track you just wont gain any more et with a bigger cam cause the 60 foot will just drop after that. id spin it to 6500 regardless of what cam you go with, and if you can sneek in atleast a 3000 stall that will help alot. the l92 heads are bad *** but do have big chambers, try to get a .030 mill on them before you throw them on.
Old Jul 3, 2010 | 12:40 AM
Oldtoad's Avatar
Is that the only cam? There is a 112 and a 114 LSA. Will either work. The ramp is kind of aggresive, will it last 35k or 45k. I seen a couple cams that seem interesting on Parke10-Towing 5.3 thread but they were running smaller engines.
Old Jul 3, 2010 | 09:49 AM
Coban's Avatar
L92 heads do not respond well to single pattern cams. Look at one of Comp's new LSr cams. Look at the 215/223 in particular. I think this cam would do well on both heads.
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
caliSSclone
Jul 23, 2015 11:04 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
