Big Problem, Help Please!!!!!!
Old Feb 10, 2006 | 03:39 PM
  #41
Unhappy
Originally Posted by SS_bnoon_SS
I would pull the plugs and turn the engine over by hand a few times. Sounds to me like a spun or "walked" main bearing, or partially blocked oil pickup/pump. Metal rubbing past metal is about the only thing that creates a sewing machine sound.
All of the valvetrain ideas go out the window with the sewing machine sound. Bent valves/pushrods, broken rokers, failed springs, failed lifters... all pretty much make a clatter sound, not sewing machine... Sorry to say, I think it's bottom end.
Man.....don't make him cry... I know I would if this was me with the problem reading your reply!!
Jim
Old Feb 10, 2006 | 04:47 PM
  #42
KLUG'S SS's Avatar
FormerVendor
Jim
Well I do know that I am starting to get very frustrated with my truck. I don't really believe that it is a bearing or anything in the bottom end. The reason that I say this is I even drained my oil and found no signs of metal at all.
Old Feb 10, 2006 | 04:49 PM
  #43
SS_bnoon_SS's Avatar
Jim
Yes, but now perhaps he has an excuse to buy a 402 rotating assembly... Does that make you feel better?
Makes me jelous as a ****!
Old Feb 10, 2006 | 04:54 PM
  #44
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Well then man the only thing to do is pull the heads replace the lifters, check the springs on a tensioner, check the pushrods, and take a look at the valves. I still find it extremely wierd there isnt an SES light. Have you scanned the computer yet to see if there is a SES code in there that hasnt set a light. LIke I said before not all will set a light. But then again if it is something major enough for you to lose that kind of power you would think it would set a light. Im as confused as you are
Old Feb 10, 2006 | 07:56 PM
  #45
Post
Too bad your not down here in Houston or in the vacintity. I would tell you just to come over, and I would scan it for you. Oooppps, I would come to you and scan it for you.
Michigan a little too far and cold!
PUT IT ON A SCANNER BEFORE YOU DO ANYTHING ELSE!!!!! BORROW ONE OR MAY BE A GOOD TIME TO BUY ONE!
Jim
Old Feb 10, 2006 | 11:32 PM
  #46
Grey Silver's Avatar
11 Second Club
Take a look at the little wires in the maf. They get a coating on them from the oiled filter. Starts and idles ok, big power loss, and no code. I've had this happen on 2 trucks w/ k&n filters. I cleaned the wires and fixed the problem. The wires are shiny when they're clean.
Old Feb 11, 2006 | 05:45 PM
  #47
Yelo's Avatar
Have you tried re-setting the pcm ??...it may just be a computer issue
jscherbs
Mar 24, 2017 07:20 PM
thompson
Sep 30, 2015 09:48 AM
Dawas
Sep 20, 2015 12:00 PM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
