Big boost build questions
Old Jul 16, 2005 | 12:28 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Big boost build questions
What exactly do I have to do to the bottom end to be able to handle big boost levels? By big boost I mean whatever the Radix can produce without damaging the S/C. By the way what will the Radix make and not destroy itself? When I do a rebuild I plan to go to a 6.0 and bore it a little and want to slap on the most boost the Radix will put out. I need a 500 or 600 rwhp daily driver.
Old Jul 18, 2005 | 09:51 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Radix guys jump in here and correct me if I'm wrong, but I think the max, max, max boost you'll see if the stars are all aligned, and you're holding your mouth right is 10-11 psi on stock 6.0 cubes. I think a reasonable target will be 9psi.
If that is true, a stock LQ9 will hold run that boost (esp. intercooled) all day long. Spend the extra money on a top flight exhaust system, IMO.
Old Jul 18, 2005 | 10:03 AM
Ruffrider5.3's Avatar
I know someone that is running 12 lbs on a stock 6.0 with bolt ons and puts down 550 rwhp. Radix of course. I think it may depend on how high flow your exhaust is to wether or not you can build big boost. More flow=less boost, I think that is how it works.
Old Jul 18, 2005 | 10:12 AM
Wilde Racing's Avatar
How do I change this text
I would look into some good pistons, (going to have to buy them anyway) If you only run around 10psi I would thing the rest of the rotating assy. would be o.k, but some good studs and rod bolts would be a good idea too.
Old Jul 18, 2005 | 10:15 AM
ATIBlownZ71's Avatar
You need a good cam in there to keep the boost in the cylinder. Ruffrider is right the more the exhaust scavenges the less boost you will see.
Old Jul 18, 2005 | 07:58 PM
1SlowHoe's Avatar
I'm not real smart on this boost stuff so answer me this. Is 9 pounds of boost on a normal 6.0 and 9 pounds on a very well breathing 6.0 going to make a big power difference? Or am I only going to see 20hp or so like with a good exhaust system? What are the rwhp difference in a radix'd 5.3 and a radix'd 6.0 everything else being equal?
Old Jul 18, 2005 | 08:49 PM
You may see less boost if you open up the exhaust, I don't know if the exhaust gains will supercede the loss of boost, it may lose a lbs at the most I believe. The 6.0 is a monster and cannot really be compared too the 5.3 due to piston size, stroke, etc. I have seen the 5.3s making like high 3 hundreds, when the 6.0 will make in the 4 hundreds. What do I know, I dont even have a supercharger.
Silveradorst07
Dec 31, 2015 12:04 AM
Raylar Engineering
Aug 26, 2015 10:36 PM
USMCvet0311
Aug 14, 2015 10:28 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
76k10chase
Jul 17, 2015 01:48 PM
