Best mods for under 2K
Originally Posted by 99 Blue Z71
where can I get some of this stuff.
whats a good Stall and servo? i think ill go with ASM headers
The Yank TT3000 is the most popular choice here. I heard ASM headers fit kinda poorly, I'd get TOGs if it were my truck. Best build quality I've seen. Thorley's are great too apparently and lesser priced.
A servo is an apply piston for the 1-2 and 3-4 shifts. There are two in the 4L60E, intermediate and overdrive...each for the previously mentioned shifts.
The billet intermediate holds 35% greater than the 'Vette and the 'Vette is about 5-10% over stock. So you're talking 40-50% greater capacity. The billet OD is 50% greater than the OE OD servo...there is no 'Vette OD servo.
ok thanks guys! TOG headers look good. thanks for the links!
one more thing..how much will all this take off my e/t? I went to the track 2 weeks ago for the first time and ran a 16.1 at 84xx. im goin back again tomorrow night and im takin off my toolbox and tailgait.
buy the cam kit from allan at Futral Motorsports www.futralmotorsports.com He will grind you a custom cam given your mods and what you want to do.
A stall w/ traction should kill .3-.5 easily. Cam is good for about 18-25rwhp dependant on duration...but that's a solid .2 I'd say. LTs add 13-20rwhp I'd estimate so there could be another .2
I usually factor ~10rwhp = .10 less in 1/4 mi times. You could get about a second off your truck with those mods.
Since you have a '99, have you checked to see if you are suffering False Knock?
i probly wont do the cam this time around. I was eyeing some 20'' SS wheels tho.. not shure about the false knock... I do have CSN if that what your talking about..
20" wheels will slow ya down quite a bit, I'd consider 3.90:1 or 4.10:1 gears to make up for that.
CSN?
CSN is Cold Start Knock. when you crank it up in cold weather the pistons slap for about 10-15 seconds. I might not even get the 20's I was just lookin at em..they do look mint tho. if i did get em id get 4.10's and a eton locker.
GM1697
Sep 9, 2015 01:52 PM
