Best 5.3 CAM
Old May 15, 2003 | 12:53 PM
blemoine02's Avatar
Default Best 5.3 CAM
im looking to install a cam i hear that the ls6 cam is a good one but i want a cam that i wont have to change agian
i plan to use a supercharger in the future but for now im spraying 100 shot let me know the best cam i can use and would i have to change the vavle train and what would be the best to use
Old May 18, 2003 | 11:02 AM
blemoine02's Avatar
Default Re: Best 5.3 CAM
can anyone help me
Old May 18, 2003 | 11:31 AM
If you don't want to change valvesprings Crane makes a 206/216 cam that will work stock valvesprings and should give a healthy increase in power with a smooth idle.With anything more you would need to change the valvesprings.
Old May 18, 2003 | 11:35 AM
hohl's Avatar
I don't think anyone has given you any feedback because there is no one best cam for the 5.3. You have to give a little more information about what you are looking for. You out to make as much power as possible or are you looking for more low and mid torque? You have a torque converter?
Give a little more information for exactly what you are looking for and I am sure the resident cam expert, BigTex, would be more than happy to help.
My two cents about cam selection would be, simply based on the fact you mentioned wou want to supercharge this engine, would be to go with a cam with a little more lift and duration on the exhaust side. You'll have no problem getting air into the chamber and making it easier to get out will help you make more power. As for lift and LSA, that depends entirely on what you are looking for. With a long duration cam, I recommend getting a little more LSA to bring the power down to a more useful RPM.
JordanH
Aug 8, 2015 07:59 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
