Bent pulley on water pump.
Old Jan 9, 2008 | 07:02 PM
timmer1's Avatar
Default Bent pulley on water pump.
Hey, just discovered that I have a bent pulley on my water pump. Does anybody happen to have one laying around for a 6.0l? Or where could I go get one? Is that one of the pulleys if you get an underdrive pulley set? Thanks. Tim
Old Jan 9, 2008 | 10:15 PM
1989k1500's Avatar
Doesnt come with an underdrive. Its pressed on to the pump.
How did it get bent? Might just want to replace the pump, they are around $130, fyi.
Old Jan 9, 2008 | 10:44 PM
hirdlej's Avatar
I'll sell you a like new pump with pulley, thermo housing, thermo, belt tensioner fan and fan clutch for $80
Old Jan 10, 2008 | 08:43 PM
low_life96's Avatar
i dont thank u can just buy the pulley by it self i that u haft to have the hole waterpump
Old Jan 10, 2008 | 08:59 PM
timmer1's Avatar
Thanks for the offer on the water pump, but if at all possible, I'd like to find just the pulley. I called Autozone, and they have one, but it's $50. Too much for a pulley if you ask me. Only thing wrong with mine is that the outer edge got mangled a little bit by some vice grips, when I was trying to take off the clutch fan. At the time I didn't have a belt to put on it to hold it still, so being impatient, I did that. Unfortunately, I think that may be why my belt it squealing and wore out. Maybe not tho. Didn't start squealing until I flushed the coolant and it got on the belt. I guess it puts a film on the belt, from what I've been told. Thanks for the replies.
Old Jan 10, 2008 | 09:29 PM
oldred95's Avatar
I don't think there is any way under normal circumstances for the pulley to get bent. Are you sure its not the water pump bearing going bad and causing a wobble that makes the pulley look bent? How many miles on it? Once they get around 100k the water pumps usually start leaking or a bearing goes bad which causes it to leak.
Vortec350ss
Jan 12, 2016 10:36 PM
turbo6c3
Oct 5, 2015 06:11 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
