benefits of ls6 intake on our trucks.
Old Dec 8, 2004 | 09:05 PM
  #21
BigTex's Avatar
Originally Posted by Scream
I'm curious to see some more results with the LS2 intake. I wonder if you could use the Multec II injectors, 97-98 Corvette rails/crossover, and an LS2 intake on a truck.
Nope, its not going to be that easy. Here is a pic I took of the LS2 intake with the longer bosch LS1 injectors and a 97 C5 fuel rail. The rail sits on the top of the manifold and the injectos need another 3/8" to seat fully. No way the truck injectors would fit in this setup. Its going to need some custom rails to work.
Well, an 04 or 05 truck with the returnless system could run the LS2 fuel rail.
Old Dec 8, 2004 | 09:07 PM
  #22
BigTex's Avatar
You could get the truck rails and injectors mounted, but its an ugly beast when complete:
Old Dec 8, 2004 | 09:15 PM
  #23
BigTex's Avatar
Originally Posted by GoldenVelvet
General thinking would tell you that the LS2 is going to breath deeper then the LS6. But the problem is you would need to have a motor with a set of lungs to take advantage of it. Big cubes, high output, or boost to take full advantage of it.
I agree with this part, but not with the rest.
Besides the better flowing intake of the LS2, here is another payoff for those of us willing to give it a try:
Old Dec 8, 2004 | 11:11 PM
  #24
Yelo's Avatar
Originally Posted by XLR8NSS
Yelo - I wasn't bashing what you said or anything so please don't take it that way. I only say that because I thought I heard a hint of disgust in your reply.
It wasn't taken that way at all.....and after re-reading what I wrote (I was walking out the door to go to work and was typing in a hurry) I realized that it was kind of harsh.....
Old Dec 8, 2004 | 11:15 PM
  #25
Yelo's Avatar
Hey....that's about how the LS1 manifold looks on my truck , now do y'all understand why I am loath to take pictures of it....
Old Dec 8, 2004 | 11:21 PM
  #26
GREGGO's Avatar
Just got me an LS6 Intake for my project. But like was said above... I will be going for 450+ to the wheels when done on motor.
Old Dec 8, 2004 | 11:52 PM
  #27
silent1's Avatar
I haven't posted much on my set up since I'm still working on a couple of things. I'm running the 90mm FAST intake on my 427 and can definitely feel a difference from the truck intake. Granted, I actually need all the air I can get. With the truck intake, my power would start to drop off at about 5200 RPM's. With the FAST, my power doesn't drop off. I shift at 6300 RPM's. Also, my 60ft's are down from 1.82's to consistent 1.75's. These times should improve when I resolve my lifter issues that I'm having. Once I get everything done (in about 2 weeks) I'll do my best to get some pics of the setup and try to answer questions about the swap.
Old Dec 9, 2004 | 07:29 AM
  #28
Scream's Avatar
MOOBIES Moderator
Richard, couldn't you get a crossover tube made?
Old Dec 9, 2004 | 09:16 AM
  #29
BigTex's Avatar
Scream - Yes you can. I had a couple of ideas. One is to take the existing truck crossover and cut each side off just before the first bends. Then braze on some smooth 90* elbows and connect each side with fuel hose. Could be done with AN fittings and braded line if desired. You'd still have the bulky rails though.
I think a better look would be using the 97 C5 rail I have, cutting the crossover tube at the sides so the injectors will seat fully. Then use black fuel hose to connect them. Then it would have a clean factory look and proper low profile side rails.
Custom billet side rails could be used with an aftermarket fuel pressure regulator to feed the return line. More expensive, but very cool.
Old Dec 9, 2004 | 09:39 AM
  #30
marc_w's Avatar
Comp Cam xr265hr
0.522/0.529 inch intake exhaust, 212deg intake/218deg exhaust, 114deg lob displacement
Truck intake= HP/TQ, 429/422 @5900/5000rpms
LS1 intake= HP/TQ, 450/439 @5900/5000rpms
LS6 intake= HP/TQ, 459/447 @5800/5000rpms
FAST intake= HP/TQ, 462/450 @5900/5000rpms
I personally think this is valid... I'm runnnig a cam with similar specs, and I'm not crazy about my top-end performance. I see my scanned 'delivered engine torque' level out at 400-410 ft/lbs around 4,000-4,500rpm. I'm not sure if I'm correct here, but I'd expect it to keep building with RPM's. It's only really noticeable by SOTP at the track, when I'm winding out second gear.
My 220/220 112 definitely had more up top... but unfortunately I didn't scan any power output at the time. I can't say for sure if it was cam specs vs cam specs that caused it... or if it's possibly an intake design thing.
I'll be picking up a LS6 or a used LSX over the winter... I'm planning on running LS1 heads too - so I wanted a proven/matched setup. I'd ideally like to do the swap all at once, but I also like to feel results from individual mods. Maybe I'll build the intake and get it on before-hand.
