Belt Tensioner Rocking After Cam
Old Jul 8, 2014 | 09:54 PM
MikeD.'s Avatar
Default Belt Tensioner Rocking After Cam
Hey guys, just finished up my 220r cam install on my 2007 Classic Sierra, 4.8. I was freaking out because I kept hearing a knocking sound, then I noticed my belt tensioner, was rocking back and forth about 1/4 of an inch. The truck is not tuned yet, just finished the thing a few hours ago. Just wondering if this is just due to the idle bouncing around a bit? Or belt alignment? Thanks.
Old Jul 8, 2014 | 10:01 PM
00ChevyScott's Avatar
Wearin' da big hat
If the engine is surging or loping pretty hard, it could be. You may want to try a new tensioner anyways to see if maybe the spring is worn out. Does the crank pulley wobble or is it spinning true?
Old Jul 8, 2014 | 10:11 PM
MikeD.'s Avatar
It's loping pretty hard without the tune, a from what I can see the crank pulley is spinning true.
Old Jul 8, 2014 | 10:15 PM
Wearin' da big hat
I'd imagine it should clear up a little with a more stable idle. It is recommended to replace belt tensioners when you replace the serpentine belt as they do weaken with time (if yours is original, it's ~8 years old).
5.3Okasai
Mar 9, 2022 01:07 PM
wrb002
Aug 31, 2015 12:30 PM
signguy62
Jul 29, 2015 10:49 PM
blownss27
Jul 20, 2015 08:59 AM
