belt tensioner, adjustable?
Old 09-27-2017, 08:48 PM
JJK
JJK's Avatar
Default belt tensioner, adjustable?
I have a 13' turbo 6.2 Silverado. I've thrown my belt several times now, happens at higher rpm's on the boost. I'm guessing I need an adjustable tensioner. Which one would be recommended? TIA!
Old 09-27-2017, 10:12 PM
GMCSIERRA5.3's Avatar
Katech makes a real good tensioner
JJK (09-27-2017)
Old 09-28-2017, 06:17 AM
madmann26's Avatar
Check your pulley alignment with a laser tool.
Throwing belts is usually one of these things:
1. Pulley alignment off
2. Crank pulley spinning (not pinned)
3. Too long of belt
Old 09-28-2017, 07:07 AM
03sierraslt's Avatar
3. Too long of belt
Yes this...
Old 09-28-2017, 09:45 AM
Jaysz28's Avatar
I had that happen on my firebird. I swapped out the actually pulley for one with taller 'sides' that fixed the problem.
I would check off madmann's list first though.
Old 09-28-2017, 12:05 PM
JJK
JJK's Avatar
3. Too long of belt
Thanks! Is there a way of checking the alignment without buying an expensive laser kit?
Old 09-28-2017, 12:14 PM
madmann26's Avatar
A straightedge.
My money is on the balancer spinning though.
Old 09-28-2017, 12:26 PM
JJK
JJK's Avatar
A straightedge.
That makes sense. This might be a stupid question, but as far as the balancer, is that pinned stock or is that a mod?
Old 09-28-2017, 12:37 PM
terravast4's Avatar
Its a mod. You can. Buy a kit for pinning the crank. Its a must for any decent ammount of power
Old 09-28-2017, 01:59 PM
JJK
JJK's Avatar
Got it.. Sounds like I better get this done. Thanks for the feedback
