Bad Rings?
Old May 10, 2004 | 10:48 PM
OBXMarine's Avatar
Question Bad Rings?
Well, I was doing the 60k maintenance and decided to swap out the Iridium NGK's with some of the standard TR-55's. Upon pulling the plugs, I noticed quite a bit of oil on the threads of all the plugs. I regapped them about 2k ago and don't recall seeing this before. The tips look good except for a greeninsh tint. Too rich? I find it hard to believe I that the rings are bad on all 8 cylinders so what else is there? The PCV valve crossed my mind since I just replaced that the other week...
Old May 11, 2004 | 12:05 AM
bigguy75inches's Avatar
check your compression to see if your rings are going bad.... i didnt think my rings were bad either,, turns out that 4 of the cylinders have rings that are in various stages of blown.
Old May 11, 2004 | 06:01 AM
mudz5.3's Avatar
Maybe check the valve cover gaskets, make sure there not leaking?
Old May 11, 2004 | 07:25 AM
OBXMarine's Avatar
Checked those while under the hood last night. Everything looks nice and clean.
I guess I can pick up a compression tester this weekend. Going out of town for a few days, and it just happens to coincide with a Test and Tune at the local track.
Old May 11, 2004 | 08:09 AM
BigKID's Avatar
Are you sure it was oil? Do you use antisieze on your plugs before you put them in? Once it has been on there for a few miles, it will 'cook' (for lack of better terms) and look like burnt oil.
Old May 11, 2004 | 01:47 PM
OBXMarine's Avatar
I 'm busted! I haven't put anti-seize on them. I know I should...
Most of the plugs had a drop of oil hanging on the threads. The other few were more like sludge. I'll try get get some pics tomorrow....
Thanks for the interest!
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
OHsixLS3
Nov 22, 2015 07:45 PM
dsbodley
Nov 14, 2015 09:46 PM
turbo6c3
Oct 5, 2015 06:11 PM
