Bad Rings?
Well, I was doing the 60k maintenance and decided to swap out the Iridium NGK's with some of the standard TR-55's. Upon pulling the plugs, I noticed quite a bit of oil on the threads of all the plugs. I regapped them about 2k ago and don't recall seeing this before. The tips look good except for a greeninsh tint. Too rich? I find it hard to believe I that the rings are bad on all 8 cylinders so what else is there? The PCV valve crossed my mind since I just replaced that the other week...
Originally Posted by mudz5.3
Maybe check the valve cover gaskets, make sure there not leaking?
I guess I can pick up a compression tester this weekend. Going out of town for a few days, and it just happens to coincide with a Test and Tune at the local track.
Are you sure it was oil? Do you use antisieze on your plugs before you put them in? Once it has been on there for a few miles, it will 'cook' (for lack of better terms) and look like burnt oil.
I 'm busted! I haven't put anti-seize on them. I know I should...
Most of the plugs had a drop of oil hanging on the threads. The other few were more like sludge. I'll try get get some pics tomorrow....
Thanks for the interest!
