Backfiring after cam install!!!!!please help!!!!
Old Mar 5, 2009 | 06:49 PM
And it's fine until I give it more than 1/4 throttle. If it was valves wouldn't it do it all the time?
Old Mar 5, 2009 | 06:51 PM
sonoma43's Avatar
right after I did my cam until we got it tuned anything over 3k it would hesitate real bad....it was dumping fuel and boggin it out to. This could be a tuning issue.
Old Mar 5, 2009 | 06:52 PM
Sheephead's Avatar
Did you check push rod lengths?
What would make it accelerate while driving down the road? If I pull out somewhere, I don't even have to give it any gas, and it's really slow coming down from a rev.
Old Mar 5, 2009 | 06:53 PM
Push rod length is 7.400" like TSP told me to get, and I haven't checked the plugs but hope to tonight?
Old Mar 5, 2009 | 06:54 PM
sonoma43's Avatar
you have tuning issues!!! your idle tune is all off which if your tuner didnt do that he may have done a half *** job on the rest of the tune
Old Mar 5, 2009 | 06:58 PM
That's kinda what I was thinking. I am really certain that I made sure of the timing. Everything was good when I put the cover on. He says that it's a valvetrain problem. I don't see what that has to do with why it accelerates going down the road and why I don't have to push the gas to go. I am going to ask him again tonight. I will keep everyone posted.
Old Mar 5, 2009 | 07:01 PM
MikeGyver's Avatar
That's the symptoms of a vacuum leak...
Old Mar 5, 2009 | 07:06 PM
sonoma43's Avatar
Or a bad tuner...he at least didnt idle tune at all
Old Mar 5, 2009 | 07:08 PM
TURBHOE's Avatar
your base runing idle airflow is set too high. it will cause it to act like cruise control. or a vacuum leak, did you get the valve cover lines all hooked up?
