back pressure
Old May 16, 2005 | 10:51 AM
jps_2001's Avatar
Default back pressure
I want to gut my cats and put true dual dynomax muffs on my 99 5.3, but the gey at the muff shop said that i would have problems b/c it would my backpressure to low and it would not run right. Is this true?
Old May 16, 2005 | 11:19 AM
LVSTOGOFST2002's Avatar
absolutely not, in my experiance, and i believe everyone here on this board will back me up, is that lsx motors do not need a ton of backpressure, like some of your run of the mill, older style small block chev's. Open that baby up, and you'll be happy.
Old May 16, 2005 | 04:57 PM
is ur truck stock? if so, backpressure would make a difference. without enough of it, your initial torque off of the line is greatly damped. Atleast I noticed this big time on mine with true duals, being almost completly stock, (just an intake). but... ur in upper rpms, ur motor will flow alot better which will give u a little better pull. my 2 cents
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
